Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 08-03-2001, 10:07 AM
Jagmeister Jagmeister is offline
Clattering noise from LF
I have just started getting a clattering noise from the left front when I make right turns.
I only notice it when on exit ramps or highway curves where I am moving fairly fast.
Will jack it up this weekend and take a close look under there but wondered if anyone had any ideas of what I should be looking for.
Thanks,
Matt Grimes
95 Infinity G20t - The Daily Driver
86 Jaguar XJ6 w/350cu V8 - For Nice Days
Old 08-03-2001, 10:44 AM
Dprotech's Avatar
Dprotech Dprotech is offline
Send a message via ICQ to Dprotech
I had that noise once ...you can duplicate it when the car is standing still and you have someone outside listen as you turn your wheels.
My problem was a misaligned brake rotor shield. Dealer fixed it in 20 minutes.
G20t ..where t stands for Turbo and if not ..why not?
Old 08-05-2001, 02:27 PM
1PNYBOY 1PNYBOY is offline
What year? If it is one of the earlier models '91-'96 then it is probably the plastic side engine cover. They located on the left and right side of the engine in the wheel well area. The clips that secure them break and the plastic shield flaps around when driving at highway speeds or turning. While the car is stopped, just turn the wheel sharply and look inside, you should see the plastic splash shield loose or broken.
Old 08-05-2001, 02:34 PM
ales's Avatar
ales ales is offline
Forza Schumacher
1PNYBOY,
I'm so glad that you joined us here on this humble board! I mean it!
Old 08-05-2001, 04:30 PM
1PNYBOY got it right. I crawled under there and the plastic engine shield had ripped loose and gotten twisted around up beside the axle.
During the investigation process I also discovered my left headlight has a broken mounting bracket. Gadzooks! One thing after of another
Matt Grimes
Strange Noise from Trans OR? 70camaro Silverado 3 02-13-2011 07:32 AM
Noise from Engine Bay jabranko Engineering/ Technical 1 12-16-2010 06:22 PM
2001 Accord Manual --weird hissing / grinding noise from Back seat area! shivparekh Accord/TSX/Accord Hybrid 7 01-10-2010 07:42 AM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 06:25 PM
clatter noise. like noisy lifters hbhayes Ram Pickup | Ram SRT10 1 01-06-2005 03:46 PM
