Old 11-29-2005, 11:35 AM
lazio2000 lazio2000 is offline
Dodge Grand Caravan 96 (Transmission)
I have this vehicle at 165,000 km.
It is a 3.8V with the transmission already done at 65,000 km at no additional cost from the dealer.
I am fully aware of the transmission glitches that affect these vehicles and before I fully ditch the van ,I would like to attempt to investigate the source of the problem.
Here are the symptoms:
I was driving under normal conditions and suddenly headr a clunk from the engine, the vehicle hesitated and then remained stuck in first gear since. (no shifting under N selection, reverse works ok, I have not tried the other ones).
I have noticed aftewards that the tachometer is dead and there is a visible leak of fluid (I suppose transmission fluid) from underside.
I did a routine instrument check and everithing works, could not get a trouble code from the digital panel.
I am suspecting that the speed sensors are gone, my question is where could I find them and if I replace them what are the chances of solving my problem.
Or is the transmission really gone for good?
Please email if you have a diagram or anything that could help ([email protected])
Appreciate your help!
Old 11-29-2005, 11:51 AM
harryliuusa harryliuusa is offline
Re: Dodge Grand Caravan 96 (Transmission)
If you see fluid, it is not/not only a sensor issue.
