Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-29-2005, 10:44 AM
randynight randynight is offline
2002 Sub P0178 code
My '02 is giving this code on the fuel sensor. Low input voltage on the fuel compensation. What's the next step? Get a dealer to check the fuel module?
Old 11-29-2005, 08:38 PM
gkindub gkindub is offline
Re: 2002 Sub P0178 code
According to my 03 service manual the code you are referencing is generated by the PCM per the fuel composition sensor. It sends the PCM info on ethanol content and fuel temp. The diagnostics for this code go on to check the output from this sensor, whether the circuit is good, bad connections, bad PCM, etc. The dealer tech will know exactly what to check.
Old 11-29-2005, 08:54 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Alcohol content and fuel temperature information is supplied to the powertrain control module (PCM) from the fuel composition sensor (FCS). The FCS has an ignition 1 circuit, a signal circuit, and a ground circuit. The FCS uses a microprocessor inside the sensor to measure the ethanol percentage and fuel temperature, and changes output signals accordingly. The signal circuit carries both the ethanol percentage, and the fuel temperature within the same signal. The signal is both variable frequency and variable pulse width. The frequency signal indicates the ethanol percentage, and the pulse width indicates fuel temperature. The PCM provides an internal pull up to 5 volts on the signal circuit, and the FCS pulls the 5 volts to ground in pulses. The normal range of operating frequency is between 50-150 Hz. The normal pulse width ranges between 1-5 milliseconds. If the PCM detects a signal less than 45 Hz DTC P0178 will set.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
