Old 11-29-2005, 10:39 AM
bubbs176 bubbs176 is offline
Voltage flux
I have a 95 Camero. I have replaced the alternator and battery in the last three months and the serpentine belt in the last two years. While driving the car the voltage fluctuates down to between 14 and 8 volts when I apply the gas. Everything runs normal when Idle and cruising. I also noticed it is temperature dependant, only happens when it is warm outside. Suggestions?
Old 11-29-2005, 02:16 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Voltage flux
Is this happening only when the a/c is on?
how's the belt tension?
Old 11-29-2005, 08:30 PM
Re: Re: Voltage flux
The a/c and radio is off. The tension seems good, I don't see an indicator. I'll check that in the next few days. A correction on the voltage flux. It drops voltage to about 12 volts. I’m assuming that is the battery voltage and the alternator is completely dropping out. Thanks for replying.
Old 11-29-2005, 08:42 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: Voltage flux
should be 14.5 at cold start, then 13 all the time. Bad computer, bad voltage regulator, bad rectifier. Seems like a classic alternator problem. Did you put a new one in or used? Might just be a crapy part.
Old 11-29-2005, 08:50 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Yeah, hope you didnt go cheap and get one from like a junkyard. Thats a big no-no.
Old 11-29-2005, 09:25 PM
NYC FRANK's Avatar
NYC FRANK NYC FRANK is offline
Wink
I have heard of and personally bought a "NEW" Alternator from Parts stores that didn't work. They're all Rebuilt using old cases. Unless you spend $300 for a new Denso or Powermaster that's what they are. It's hit or miss sometimes (Shitty quality control?). If you did get it from a store go back and have them test it. They should replace it. It's pretty common.
2000 Z28 - 391 RWHP = 11.81 ET
Cartek Tuned, Cartek 2X Cam (224/228,114,.590), Comp Cams Valvetrain,
SLP LT headers, SLP LS6 Intake, SLP Ram Air & Lid, Very! Loudmouth,
Yank 3600, 12-Bolt Moser,33 Spline Axles,HD Eaton Posi with 3.73 Gears, Dynotech Stage 3 Trans,BMR Adjustable Suspension, SLP Weld-In SFC,Line Lock,Airbag In Rt. Rear, M/T Street Slicks
Old 11-29-2005, 10:41 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Voltage flux
I had this happen once on a '75 Grand Am I used to own years ago. Turned out to be a defective winding on the armature in the alternator. Replaced alternator, problem solved. At the higher RPMs, the voltage would fall off because centrifugal force would cause the winding to short against the frame of the armature.
Old 11-30-2005, 10:40 AM
wrightz28's Avatar
'75 Grand Am?
Old 11-30-2005, 11:51 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: Voltage flux
What's a Camero???
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 11-30-2005, 09:27 PM
NYC FRANK's Avatar
. Hey Savage with a 3,000 stall,some LT headers and 3.73's with good traction you can knock over a second off your ET with no drivability Issue's and minimal MPG loss. 4.10's are brutal and you know our 10 bolts like to go boom !
Old 12-01-2005, 01:43 AM
Re: Voltage flux
well it's only a 3.8... there are a few peopel I know daily driving on 4.10s who drive... in a spirited manner... and make many track passes and are fine. Getting 25 mpg avg highway/city, and with a manual (the T5 overdrive ratio is 0.72 whereas the 4l60e overdrive is a 0.70 ratio.) I'll probably invest in a TA girdle or the like for extra insurance.
I have a 3200 (i believe) stall that is being help till I have the money
and the only longtubes for my car are custom made, so for now at least I'm going with pacesetters
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 12-01-2005, 08:02 AM
You guys are awesome. Tensioner and belt looks good. I haven't been able to duplicate the problem lately, but I am going to re-replace the alternator anyways. If I still have a problem I'll let you guys know and I'll add more symptoms. Thanks.
