Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 11-29-2005, 09:37 AM
scott733i scott733i is offline
Question Climate control unit probs...
Answers anyone? My '83 733i climate control unit...I only have defrost, and you cannot adjust the fan speed nor the temp. Whenever I try to set the unit to any other button, such as heat (whether auto or up/down), the corresponding green indicator lights illuminate, but then they dim, sometimes to completely off. And sometimes when I push one of the aforementioned buttons, the unit will start but then stop after only a few seconds. Again.....answers anyone? Thanks in advance...
Old 01-16-2010, 10:05 AM
clearkut clearkut is offline
Re: Climate control unit probs...
hello scott733i,
I am intrested in you heater issue, i have the same 83 733i, with basically the same issue(lights are on apropriatly but no selector, it worked intermittently for a short period but now there is nothing), no heater control, and stuck on defrost, only difference is my blower speed dial still works, and i belive the temp control works as well(its cold now where i live so it stays at full), but none vent selector buttons change air direction through the vents, only blows on defrost(front window only)
is this possibly a safe mode that a failed selector goes into?
just wondering if you solved your issue, I am thinking of replacing the climate control panel, but hate to go trial and error when spending money on parts.
