Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 11-29-2005, 09:05 AM
raymarquise raymarquise is offline
'95 wipers stuck
My wipers are sometimes staying stuck in the up position or in the middle of the windscreen with the switch in the 'on' position. I have to push on the wiper to get it going again. Do I need to remove the wiper motor unit to lubricate the parking mechanism??
Thanks.
Old 11-29-2005, 11:14 AM
cdru's Avatar
cdru cdru is offline
Re: '95 wipers stuck
If the wiper transmission is anything like the 97 and later models, there is a catch on the underside that either breaks or gets bent out of the way. The wipers should run backwards and catch, but with the catch bent, doesn't so the wipers go up instead of park.
Vinyl adds horsepower, right?
Old 11-30-2005, 06:17 AM
Where is the catch located??
Old 11-30-2005, 07:10 AM
LMP's Avatar
LMP LMP is offline
THis may help when you decide removing the motor. Better have talents as a contorsionist.
www.avigex.ca/xport/wiper1.jpg
www.avigex.ca/xport/wiper2.jpg
www.avigex.ca/xport/wipercircuit.jpg
www.avigex.ca/xport/wipermotorphoto1.jpg
www.avigex.ca/xport/wipermotorphoto3.jpg
www.avigex.ca/xport/wipermotorphoto8.jpg
www.avigex.ca/xport/wipermotorphoto9.jpg
www.avigex.ca/xport/wipersyndrome.pdf
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 11-30-2005, 07:44 AM
cdru's Avatar
Based off of what LMP posted, I don't think the '95 used the same type of system. So you can probably ignore what I said.
Old 11-30-2005, 03:10 PM
Thanks for the links - they were a HUGE help in getting the motor out.
I took the circuit board off - the solder joints seem fine, but the tip of one of the brushes comming off the board is worn (I guess they are brushes or contacts). Could this be the culprit?? Can I replace the brushes?? or the whole board???
Inside there is what seems to be a toothed plastic wheel with LOTS of grease on top. From another post I kind of thought this would be dry and in need of grease. Should I try to take the wheel off?? Still can't figure out how this makes the wipers park.
Thanks for all the help I've gotten. I feel I should put a check in the mail......lol.
Old 12-03-2005, 03:42 PM
Anyone knows if I need to remove the crank arm nut and take the commutator rings out to grease them?? or just pack grease into the housing under the pulse board???
Thanks.
Old 12-03-2005, 09:38 PM
LMP's Avatar
LMP LMP is offline
With PCboard removed, you have full access to the ring and PCBoard contactors so I see no reason to dismantle more than that. Just ensure the sprnged contactors do make contact woth the ring and this should ensure wipers returning to park when turned off. I do not have exactly the logic but I think the wiper switch (through the pcboard logic, timed pulses, etc) just excites the small segment that takes the wipers off park and from then on, the wipers continue the full cycle back to park from the long segment. IF at some place the large segment looses contact, wipers stop in the middle of the run.
On return to park, if small segment is not excited then wipers stay there (parked) but if small segment is excited, it passes out of park..and then again receives juice for the rest of the cycle from the long segment..and repeats. So I think the long segment contactor can be the problem...or some cracked solder linked to contact plays tricks.
PCboard is known to be a really common source of problem, there have been dozens oc ocurences on this forum and other GM products so I would not rule out redoing the solders or ordering a replacement on Ebay.
Mine has restarted playing tricks recently and I'll redo the soldering again; honestly, last time I did it, I needed a strong magnifying glass to really see the cracks..so I remelted as many solder points as I could...., that was less than 2 y ago.
Old 12-04-2005, 09:09 AM
Thanks LMP. I found a post elsewhere that says if the old grease hardens it will lift the contactors off the ring - I think thats my problem. I will remove the old grease ( which is indeed hard) and relube it.
