Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-29-2005, 08:55 AM
glorifiedb glorifiedb is offline
Question Vibration noise at higher speeds?
I've got a 2001 Wrangler with a stick shift and a week ago I was making a sharp left turn when I heard a somewhat loud pop sound. I thought it might have been the tire but I checked it and it was fine. Well, since then I've been having this vibration noise when I use the throttle at high speeds (ie. higher than 40 mph). It's only there when I push on the throttle, when I release it it goes away. Other than that everything seems fine. I have not noticed any change in performance, shifting or anything else.
Anyone got an idea on what it might be? Any help would be greatly appreciated. Thanks in advance.
Old 12-01-2005, 12:15 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Vibration noise at higher speeds?
Is this a rapid vibration or slower? Have you checked all your tires?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-01-2005, 02:12 PM
Fred, thanks for the reply. I have checked all the tires and they are fine. I don't think it's the tires because it only occurs when I push down on the throttle.
Old 12-01-2005, 03:28 PM
Hmmm....I usually go from the simplest things to more complicated. So it only occurs when you press the throttle. Have you checked all the spark plugs and wires(I think the distributorless started in '02?), and looked for leaks in the head? Sounds like you're not firing on one (or more) cylinders.
Old 12-01-2005, 05:37 PM
I have checked them and they are fine. I haven't noticed any change in performance since this happened, so I'm not sure if it has to do with not firing a cylinder.
Maybe I should clarify the noise. I described it as a vibration noise because it's constant and sounds like vibration. However, there is no actual vibration that I can feel in the driver seat. I hope that's not too confusing, it's just hard to explain the noise.
Old 12-01-2005, 09:03 PM
Does it sound like, "chika chika chika chika", and go faster the faster you go? Sounds a bit like a problem someone described with the front drive shaft. Check this forum (search "front drive shaft" w/o the quotes) and you should find it. Sounds like what you're hearing, and the other post described the noise as being right under your feet, like you did.
Hope that helps.
Old 12-01-2005, 09:04 PM
Sorry, also meant to say sounds a bit like universal joints also.
Old 12-03-2005, 10:56 PM
twisterTJ's Avatar
twisterTJ twisterTJ is offline
Re: Re: Vibration noise at higher speeds?
I agree. I have a '99 TJ and experienced a similar problem. Turned out a cap on the rear U-joint had partly broken off. Unfortunately it's a fairly common problem, especially in the offroading realm (at least in my experience).
TwisterTJ
