Old 11-29-2005, 08:35 AM
71chaz 71chaz is offline
2002 accord passenger power window out
The front passenger power window on my 2002 accord stopped working all of a sudden. All other windows are fine. Is there a relay or something else I can check or replace to fix this problem? The window just abruptly stopped working instead of going out gradually so I'm hoping that the window motor is not the problem.
Any ideas?
Old 11-30-2005, 01:08 AM
mpumas mpumas is offline
Re: 2002 accord passenger power window out
Each power window is individually fused. The fuses are in the under hood fuse box. Replace it once if it is blown. If it blows again you may have a jammed window, a bad master switch on the drivers side door or bad switch on the passenger side or a bad motor.
