Old 11-29-2005, 02:04 AM
matraboy matraboy is offline
2000 Caravan rad control module
Hi All, wonder if anyone can help me. I have a 2000 Dodge Caravan and the rad fans have stopped working. The engine warning light is on and I've had the error checked which is 1491 - something to do with the rad control module.
Does anyone know were this module is located?? I can find anything that looks like the part I've just got from the dealer.
Many Thanks
Old 11-29-2005, 03:05 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 2000 Caravan rad control module
P1491- Open or shorted condition detected within the radiator fan control relay circuit. The radiator fans are powered on/off through the engine computer known as the PCM. The PCM controls the ground to the fans signaling them to come on or off. Areas to look for: HI/LO fan relay (found in your underhood fuse box known as the Power Distribution Center), PCM, related wiring
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 11-29-2005, 12:46 PM
B33p3r B33p3r is offline
The relay I believe is actually a pulse width modulator. I don't believe the PCM controls the ground, on the contrary I think it supllies the B+. I'm not sure where it's located in the van because I never had to look for it yet but it you follow the Dark brown/ Dark green wire (which is the hot to your rad fans) back, it will take you to your relay.
Old 11-13-2006, 03:31 PM
sdbowmanii sdbowmanii is offline
Many Thanks
It is located underneath the Driver Side Headlight. The Headlight has to be removed.
Old 11-13-2006, 05:47 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Read a thread somewhere describing access to it via the drivers side wheel well. Have to remove the wheel well liner. Might try that first.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-16-2006, 09:45 AM
Stretch58 Stretch58 is offline
Fan Relay as mentioned above, is below the driver's side headlight assm. After removing the headlight module, take the cover off the Relay(actually a solid state device). Disconnect the connector on the Relay. Drill out the 2 retaining rivets.
When installing a new unit, make sure the new one is making tight contact on all of the flat surface, as that conducts heat away from the Relay. If not, it may fail again. I understand rivets come with the new unit.
Retired USAF/ Nuclear Plant Controls Dude
Had Recently
1996 Caravan 3.0 Great Car
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
