Engine Problem
On thanksgiving i was driving down the road when knocking noises started coming from the engine. There was no where to pull over so i kept going till i could find somewhere to pull over. About 30 seconds later the engine seized and i coasted the rest of the way down the road. It got towed to the shop the next morning and they promptly informed me that i needed a new engine. The car only has 110,000 miles on it and the only warning that i had of a possilbe problem was a slight knocking i heard one day two weeks ago but it stoped the next day. Does anybody have any ideas what could have done this to my engine?
Re: Engine Problem
Re: Engine Problem
Hopefully it was replaced because it is recommend that you replace the timing belt every 60,000 miles.
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads. |
Re: Engine Problem
the shop told you that you needed a new engine? did they tell you what was wrong with the one you had, or did they tell you what happened?
ASK QUESTIONS or you will get screwed. |
Re: Engine Problem
when was the last time you had an oil change as well? my friend had his oil changed and they left the ring on the filter, all the oil came out and his engine was nearly seized as well
any smoke at all?
![]() Don't act like you don't love it.
503/2000 |
Re: Engine Problem
I had the timing belt, water pump, tensioner belt, pulleys,and thermostat changed about 7 months ago. There was no smoke and I had the oil changed about a month ago. When the car shutoff though right before the engine seized the oil light did come on. I am also having the shop take the engine apart to figure out what exactly caused this.
Re: Re: Engine Problem
did you also have the alternator belt and power steering belt changed along with the other things? |
Re: Re: Re: Engine Problem
No accesory belt would have any impact on an engine siezing up like that. Faulty oil change maybe, but hopefully if your car dumped 5 quarts of oil you would notice it when you left the driveway in the morning. Were you the first person to own the car? If not, the other person might have beat the car to shit and then sold it before this happened because they knew it was innevitable. If that is the case i appologize for all the assholes in the world.
2000 Fed. Spec GT-"Lafawnduh" Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp |
Re: Re: Re: Re: Engine Problem
Re: Re: Re: Re: Re: Engine Problem
Well I guess in that case it would. I was assuming that you meant the belt alone could have caused the problem, i was not thinking that it would hit a more important component.
Re: Engine Problem
Does anybody know how much a engine plus labor would cost?
Re: Engine Problem
Have seen gt motors go on ebay for around $600 before Shipping and handling. Not sure about installation. Buddy of mine has a Celica GTS and he blew his motor and he had to replace it. It ran him around $4300 for a rebuilt motor and to have it installed. I know it's not an Eclipse but that may give you an Ideal
No he bought one that was already rebuilt he didn't have his rebuilt. Small town in West Virginia and the person that owns the Toyota Dealership owns pretty much every dealership in the area and there are no private shops in the area that will touch imports. I otherwords they have open range to charge people out the ass for anything they do.
