87-93 dash?
old question but was never answered, was wondering if anyone swaped the dash form a 86 for a newer one from a 87-93? and if so did any of the brackets need to be changed or customized? im in need of a new dash and i have one in great shape from a 91 and wanted to install it..
Re: 87-93 dash?
what you could do is flip though a pair chiltons, one from each era. that way you could see if the assembly and dissasembly differ dramatically. i have no idea otherwise.
free hypsi87!! Dan's White Horse Bring back Melt Crew 002 - 3657 posts can't be wrong! |
the chiltions dont give u to much behind the dash thats what i need to know
Re: 87-93 dash?
they give detaled walkthroughs of dissassembly and assembly, its just an idea and not a very good one - but you could see if they have similar support structures through the comparison. or you could go down to the pick'n'pull and check it out first hand. or you could take a chance that ford used the same pieces to attatch the supports to the car body in both generations and that although the interiors are vastly different it could be a result of different supports that have identical connections to the frame.
but these are all speculative.
the brackets behind the dash are diffrent ima try n get them from a newer mustang right now i gotta see about the wiring...not sure if im going F.I or Carb...
the brackets are a simple bolt in jus gonna replace the heater core while im here mine as well..gotta rewire the car to work with the new switches though..this is the time consuming part...
