Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 11-28-2005, 09:43 PM
violeteliza violeteliza is offline
Angry Stalls Out When Coming to Stop
I have a '90 Lebaron. Occasionally, and very sparatically, my car stalls out when I come to a stop. I never know when it is going to do this but I also don't know why. I replaced the fuel pump and fuel filter thinking that was the cause but I am now thinking it may be electrical. Wondered if anyone else had this problem and knew the cause. If you know of why it may do this please respond or email to [email protected]
Old 11-29-2005, 11:19 PM
94LebConv3La604 94LebConv3La604 is offline
Maybe check the idler, make sure it's not letting off too far.
Old 11-30-2005, 12:39 PM
Re: Stalls Out When Coming to Stop
I have had the idle adjusted, fuel lines cleaned, electrical checked, and had a diagnostic test done but the car won't stall out when it is at the shop so they have trouble finding root of problem.
Old 11-30-2005, 10:12 PM
They won't take it for a run?
Old 12-09-2005, 06:40 PM
Roleh Roleh is offline
This isn't very helpful, but learn to drive with two feet. As in, brake while revving the engine a bit.
I drove a 1992 LeBaron for 3 years that had this problem, and a friend drove a 1991 LeBaron and also had this problem. [Ironically enough, I now drive a Cirrus and no longer have this problem, but take a gander over to the Cirrus board and you'll see the same problem for a lot of thread topics]
It was obviously electrical with mine, as the power would surge. Three mechanics could not figure it out and we did the whole battery, alternator, alternator routine. Diagnostic machines did not diagnosis it. After being angry for the first year, I got over it and just learned to two foot it in the city.
Old 12-14-2005, 10:33 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
Yup, thats a common problem. Your torque converter clutch isn't unlocking the solenoid for it has gone bad, put in a new one ad it will take care of it.
Justin
Old 01-27-2006, 05:35 PM
jeff compton jeff compton is offline
Vehicle speed sensor and the connector also a very common problem on any of the older chryslers that were 3spd, as well egr valve will give you the same problem you're describing. what engine and tranny do you have?
My own cars a 90 lebaron Gtc and I work as tech at a chrysler dealer.
maybe i can lend a hand
jeff
