Old 11-28-2005, 09:29 PM
bluechevelle's Avatar
bluechevelle bluechevelle is offline
Send a message via Yahoo to bluechevelle
OK how to do a few things
I have been working at this for like 5 hours, and cant figure it out. First, how do you change the paint job on a car. I know you have to kake another layer of it or something, but I don't know how. How do you se the lasso to outline more than one thing at once? I outline something, then go to do something else and loose the original outline?
Old 11-28-2005, 10:03 PM
assad_l's Avatar
assad_l assad_l is offline
Send a message via MSN to assad_l
Re: OK how to do a few things
you dont need layers for a paint job, press on the lasoo tool and hold it the press the pologonal lasoo and select around the whole car, hold alt and deselct windows, lights, blinkers etc., Image>adjustments>desaturate, image>adjustments>variations, then work from there.
heres a tutorial webstite that should help you.
http://www.digimods.co.uk/tutorials/tutorials.htm
Assad..
starting 180sx project soon
http://www.youtube.com/watch?v=aGRodKEfeZ4 <<<CHECK IT LOLL
Old 11-28-2005, 11:59 PM
MRSX20's Avatar
MRSX20 MRSX20 is offline
No offence man but just go to the tut's section and you'll find prettywell anything you want to know.
Old 11-29-2005, 01:31 AM
MonsterBengt MonsterBengt is offline
Originally Posted by bluechevelle
...How do you se the lasso to outline more than one thing at once? I outline something, then go to do something else and loose the original outline?
Mark the 'Add to Selection' on the upper toolbar when in Lasso mode
Old 11-29-2005, 10:17 AM
TSA15's Avatar
TSA15 TSA15 is offline
I hate this... I have Corel photopaint. So, I can do almost all the same stuff you guys can, if not more. But, I can't follow your directions because I have to do everything a different way. It's making things kinda hard to follow.
----------------------------------------------------------------------AE86, the once poor man's drift car.
Old 12-01-2005, 09:57 PM
ghetto7o2azn ghetto7o2azn is offline
Re: Re: OK how to do a few things
or when you deselect the lasso and you want to select more u can just hold shift, if u want to remove some, select alt.. or u can also use the coloring in method with the tab on the bottom of your tool bar
Old 12-02-2005, 09:17 AM
Re: Re: Re: OK how to do a few things
yea I always have the 'Add to selection' checked and hold Alt when I remove anythin
