Old 11-28-2005, 06:53 PM
kissane_brendan kissane_brendan is offline
Send a message via AIM to kissane_brendan
car seems to be choking
sometimes my car seems to be lacking fuel to the engine. This is most apparent sometimes at idle because the car sounds terrible and idles up and down at low rpms and stalls out. Also while driving it seems to be a problem at like 2500 rpms. Im not sure whats going on. Any help would be very apreciated.
thanks
Old 11-28-2005, 08:46 PM
Igovert500's Avatar
blue + red light magnet
Re: car seems to be choking
Vacuum leak, spark plugs, or 02 sensor.
o2 sensor issues would probably cause a check engine light.
Spark plugs are regular maintainence, and if they haven't been changed and you are overdue for a tuneup, then that maybe the culprit.
Otherwise you most likely have vacuum leak(s). Pop the hood, check all your hoses throughly. The best way is to pressure test (if you do a search you will find plenty of info...more available on www.stealth316.com) The other option is to try and visually/auditorily find the leak by listening for escaping air or spraying soapy water on all your hoses and looking for bubbles.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-28-2005, 11:56 PM
yeah i was thinking it was a vacumm leak because i think i can hear a leak while i drive the car, I guess I'll just start searching on how to check for that
thanks
Old 11-29-2005, 12:23 AM
MahdiVR-4 MahdiVR-4 is offline
It is probably your sparkplugs, make sure the gap is right now them and they are not miss-firering.
good luck
mahdi
Old 11-29-2005, 01:10 AM
would it be spark plugs? it isnt always like this, I replaced the spark plugs and wires just a few weeks ago and it was working great.
Old 11-29-2005, 08:46 PM
Igovert500's Avatar
What model car do you have, and what plugs/wires did you put in, and what did you gap them to?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-29-2005, 09:09 PM
i put in denso irdium plugs i cant remember tat gap exactly but it was between .039 and .043, they were already gapped fine. I have a 91 tt stealth and i dont know what kinda wires they were.
Old 11-29-2005, 10:51 PM
Is your car stock?? if not, it is better to gap them around (.32-.34) and also you might want to get some 1step colder plugs.
http://www.importpoweronline.com/cat...oducts_id=1713
good luck
mahdi
Old 11-30-2005, 11:00 AM
yeah the car is pretty much stock.
thanks
Old 12-01-2005, 08:16 AM
Igovert500's Avatar
pressure test for vacuum leaks.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-01-2005, 10:41 AM
would I do that by sealing off the intake before the intercoolers and pumping air through? Where can I find a site that tells how to effectivly check?
Old 12-01-2005, 12:09 PM
sLADe781 sLADe781 is offline
http://www.stealth316.com/2-pressuretester.htm
