Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 11-28-2005, 06:38 PM
BigFig15 BigFig15 is offline
Send a message via AIM to BigFig15
Passlock Toggle Switch
Has anyone have a pic of where the toggle switch is located? Or good directions where to find it? Any help would be very appreciated from A LOT of people
Thanks
Old 11-29-2005, 09:37 PM
e2helper e2helper is offline
Re: Passlock Toggle Switch
Toggle switch? That certainly wouldn't be production. The "switch" in system is built into an electronic module attached to ignition key cylinder. It is magnetically activated and protected from applying an external magnetic force by a 2nd "tamper switch"
Old 11-30-2005, 02:05 AM
Ok. But how do I shut off the Theft System on a 99 Malibu?
Old 12-01-2005, 05:40 PM
ednlesia's Avatar
ednlesia ednlesia is offline
Hey, hope you found the helpful info left by bcopeland on this forum.
Old 12-01-2005, 07:45 PM
I found it useful. But me and my dad still cant find it. I was really hoping for some pictures.
Old 12-01-2005, 08:43 PM
markqc markqc is offline
I tried looking for the toggle switch as well and can't find it (2000 Malibu)
I found bcopeland's info helpful but unfortunately have not been able to disconnect the theft system. Hopefully somebody will be able to confirm that such a "toggle switch" exists and how to find it. By the sounds of it, it must be a pretty common problem.
Anyone????
Thanks,
Mark
Old 12-02-2005, 08:31 AM
ednlesia's Avatar
Toggle Switch
Hey Guys, try e-mailing bcopeland with your question about the toggle switch. He returns e-mails promptly.He is real nice and seems to be real smart. Maybe he can get ya a pic or something on this. He has obviously done it before. If so, we will all be helped 'cause there are alot of us having the same problem. Seems like Chevrolet would do something about this mess eventually! Hope so. In the meantime, maybe bcopeland won't get tired of helping us all.
Old 12-02-2005, 06:30 PM
bcopeland bcopeland is offline
OK - If you can send me a place to put the picture, I can post it there or I can email the picture. I am not savvy in this. I'll email it, but I cannot email 1,000,000 of my best friends the picture. And I have good news and bad news. Good news - I guess I now know why I never had Passlock problems. Bad news - some repair shop cut my toggle switch off. I believe Wal-Mart had problems getting the car started (if the Passlock is engaged, then all the car does is blow the horn while you try and start it). So take a look and you can either 1) do the same (clip the toggle switch); or 2) turn it off. BTW, I think I think I am going to put another toggle switch on.
Old 12-02-2005, 07:40 PM
Hey bc,
Many thanks for your reply. I'm not sure how to post a picture on this forum but there must be a way to do it. Hopefully some one else will reply.
If not you can post a picture here http://www.webshots.com
Thanks,
Mark
Old 12-03-2005, 02:30 PM
Thanks - does this work? http://community.webshots.com/photo/...16259194UhnwMY
Old 12-03-2005, 02:58 PM
Thanks so much for the pictures. I assume the light spot is where I will find the switch. I see the wires but not the switch. I realize I was looking in the wrong spot. (I thought it was closer to the brake pedal) Is the switch located above the wires?
Thanks again,
Mark
Old 12-03-2005, 03:07 PM
ednlesia's Avatar
Re: Re: Passlock Toggle Switch
Originally Posted by bcopeland
Hey bcopeland, yep this link works and thanks for going through the trouble for everyone. Thanks for the e-mail too. We got the car to start with just the "relearn" cycle of turning it on and waiting for the theft light to go out and then turning it off and cranking it. After doing this cycle three times, the light stayed off and it cranks and runs fine. But, it is nice to know where that switch is if the thing ever acts up and won't quit and we can just cut the toggle switch if we have to. We did get another key made at Walmart. Just in case that was what made it act up in the first place. But, it was the old one that relearned and restarted it. So, I don't know.
Old 12-05-2005, 08:44 PM
Looked toiday for the toggle switch with no luck. I assume this vehicle (2000 Malibu, Canada) does not have the switch. I will try the "relearn" cycle to see if it helps.
Mark
Old 12-08-2005, 09:23 PM
raycorri raycorri is offline
Mark
My security light started coming on again about a year after paying the dealership $450 to replace a faulty Ignition lock cylinder. I was at my wit’s end. My wife and kids would be stuck at night in some shopping center parking lot waiting 10 minutes to reset the stupid thing. I was able to Bypass, Disable or Ghetto Hack my passlock II anti-theft system on my 2002 Oldsmobile Alero without relays or resistors. I had my local Auto wiring tech install a $5 on/off toggle switch under my dash that is connected into the yellow (key resistance/code/recognition) wire that can be cut while the engine is running to essientially bypass passlock I(1) or II(2) permanently.(I do not have nor intend to install a remote starter and I do not have an alarm on this car.) The toggle switch idea came about because of my concern that a dealership tech could possibly reset the security “fail- enable” mode or the battery could die or become disconnected for an extended period of time and reset the intended fault. All I need to do is flip a switch to break the circuit again while the car is running to take the passlock system offline. When the system is offline, the security light is on constantly.(Not flashing.) I don’t mind the light, but others may want to remove the bulb or black it out. Here’s how the setup works:
1)Switch On while engine is running – Security system is on.(Factory Setting) Security light is off. (Circuit is complete.)
2)Switch Off while engine is running – Security system goes into “fail-enable” mode and bypasses the passlock system.. Security light is illuminated.(Circuit is broken.)
3)Switch On while engine is off – Security system is on (Factory Setting)
4)Switch Off while engine is off – Security system detects this as a theft attempt
and will not allow you to start the car until you flip the switch On to complete the circuit.(Acts as a FUEL KILL SWITCH.)
Below you will find a thread and some supporting evidence of why this bypass actually works. The entire job took 25 minutes. There is an incredible link below with high resolution pictures of the wiring for your specific car. I included the actual photos that I used to gain access to my ignition lock cylinder wiring. *Special note: those with GM Class II Data Bus should leave your radio connected during the entire procedure so nothing weird happens. If you are unsure if your car is so equipped, it’s best to leave the radio connected and let it hang. Good luck and post with your success stories! 12/4/05
http://www.the12volt.com/installbay/...694&PN=1&TPN=1 Is this You? Get in your car....try to start it and find that the passlock II is screwed up again, you have to wait 10 minutes for it to reset. When it resets it starts up and runs fine. Fix-------Start the car, find the yellow wire that I'm sure you've read about, the rcode wire that is, and cut it. Shut off the car and you're done! The rcode wire on my 2001 alero is behind and to the left of the radio, you must take out the radio.....the yellow wire accompanies two other wires, the white and black, the 3 wires are alone and run inside what appears to be a cheap electrical tape that will fall apart in your hand when you start tugging on it, they are very thin wires, maybe 18 to 22. I taped off both ends of the yellow wire too.Took me about 14 days to find this out and reading no exageration 1000 posts. Forget all the relay, DEI and resister crap that I'm sure you've read about. All this writing assumes that this will continue to work.....i WILL be back here to post an update if it fails again. If you have doubts of me coming back to update a failure you can email me
http://www.insurorsservicebureau.com...cal/ISB_QA.pdf page 4, The PASS Key Module also has the ability to allow engine operation if it recognizes a system fault in the ignition key reference circuit while the engine is running. In this case the Module enters and remains in a mode which allows the engine to be started and run without reading the resistance chip. This mode requires that the original factory resistance chip key be in the ignition lock
cylinder at the time the fault occurs. During this mode, the
security light will be ON all the time. When the key reference circuit is repaired, the module will automatically reprogram itself to the mode requiring the original resistance chip.
http://www.motorage.com/motorage/dat...09/article.pdf page 3, If the correct key is in the cylinder and that circuit
fails while the engine is running, this is considered a
malfunction, not a theft attempt. The “Security” light
may turn on to warn of a system malfunction, but even if
it doesn’t, a key recognition circuit failure with the proper
key in the lock will cause the TDM to enter what GM
calls a “fail-enable” mode. Essentially, the theft-deterrent
system goes offline and the engine will start and run
with any key that turns the lock.
http://www.directwholesale.net/diagr...4&link=BULLDOG
http://www.directwholesale.net/diagr...7&link=BULLDOG
http://www.bulldogsecurity.com/ and click on vehicle wiring diagrams to select your particular make.
Also how to disable Daytime Running Lamps http://www.lightsout.org/disable.html
2001 Olds Alero Locate the DRL relay in the main fuse box under the hood, it is #22 corresponding to the diagram on the underside of the fuse box cover. Remove the relay, snip pin 87, and re-insert.
