Old 11-28-2005, 05:52 PM
HondaTuner20 HondaTuner20 is offline
odd steering issue
every once in a while i hear a pop when i turn and my steering is resistant when i turn it fights me.
Old 11-28-2005, 06:21 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: odd steering issue
check out the power steering belt and fluid
now - 2000 civic
soon - 2002 is300
Old 11-28-2005, 07:00 PM
Re: Re: odd steering issue
both are perfectly fine
Old 11-28-2005, 07:46 PM
the belt isn't squealing at all??
How's the alignment?
now - 2000 civic
soon - 2002 is300
Old 11-28-2005, 07:57 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
I have the same thing. Thought it was the balljoints... nope. thought engine mounts... nope (but did need to be replaced). Im thinking it might be the shocks.
I notice mine does it everytime when pulling into my driveway making a slow left turn. IDK what the deal is. It is a pop. Does it when acclerating and braking at times.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-28-2005, 08:49 PM
mine does that slow left thing also the wheel will just turn on its own to the left.
Old 11-28-2005, 09:55 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
i had a grand am that used to do that...it was the mounts for the lower control arms or some shit like that...it was awhile ago but you might as well check those out too.
95 Talon TSI AWD
97 Eclipse GST
Old 11-28-2005, 10:14 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Mine does the exact same thing and with only left turns(especially into the driveway). Are you sure it's not the lower ball joints?
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 11-29-2005, 06:01 AM
when i replaced my controll arm i reused my old ball joint because itwas fine also i dont thini its that because i dont see how a ball joint could make my car fight me threw turns.
Old 11-29-2005, 07:30 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
It sounds like the intermediate shaft to me. The shaft that turns the gear in the power steering rack will make a popping noise and cause heavy steering when it goes bad.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 11-29-2005, 09:13 AM
david-b's Avatar
Dave is THAT guy
I got the ball joints replaced already, and then resealed by the dealer. Those are in perfect shape. Next spring ill get it checked out. THings been making the noise forever now.
75 Monte Carlo
Old 11-29-2005, 06:30 PM
how much is that intermeidate shaft plus install with a $75 per hour labor charge do you think?
Old 11-30-2005, 04:55 AM
macder macder is offline
Send a message via MSN to macder
Re: Re: Re: odd steering issue
I can provide you with an accurate quote, but my computer can't figure out what kind of car you drive.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 11-30-2005, 06:04 AM
Re: Re: Re: Re: odd steering issue
90 GSX 5SPD
Old 11-30-2005, 06:22 PM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
Your computer must be a Pentium 1 running Windows 3.1 then.
I couldn't stop laughing when I read that. Most people usually say what kind it is and you went right ahead and made him feel like a dumbass instead.
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
