Old 11-28-2005, 05:40 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Bleeding air
Hey guys, ive heard alot about bleeding air out of ur coolant system and entire system, and it could fix problems like low coolant light, overheating etc. How exactly do u do this? is it easy? im not a mechanic but if its simple enuf i can do it. Specifics would be great, pics even better. Thanks alot guys.
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 11-29-2005, 11:31 AM
Re: Bleeding air
Hey guys, can someone help me with this please? Also is it hard to bleed the air in the brakes?
I was wondering what that green cap is on one of the hoses or w/e, it has a little sticker on it saying 1psi max, service port or something, tighten hand tight only. I opened the cap and it looks like some kind of valve or something, what is that? Anyways help wud be greatly appreciated. Thanks
Old 11-29-2005, 02:16 PM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
Re: Bleeding air
there is a nifty tool for your antifreeze. You can buy one i think it is around $100 or go to dobbs or something like that and have them do it. all it does is sucks all the air and fluid out of the system and then the colant goes back in with pressure behind it. works pretty good
Old 11-29-2005, 02:29 PM
cdru's Avatar
cdru cdru is offline
Re: Bleeding air
The tool that he is talking about is probably this one. They are on eBay occasionally new and used. There is on on there now for $45.
I can't say for all Cavaliers, but on my '97, the tank is the highest part of the system and air bubbles would normally just work themselves up to there. There is also a bleeder screw either on the bypass pipe or on the thermostat housing used to vent any trapped air in that portion of the system as well.
Vinyl adds horsepower, right?
Old 11-29-2005, 03:01 PM
Banned
Re: Bleeding air
yea that is the tool a cheaper one. i wish i had the luck of air bubbles comming to the top of my system lol
Old 11-29-2005, 07:59 PM
Re: Bleeding air
Ok thanks, is that bypass pipe the thin one coming from the coolant tank?
Old 12-16-2005, 02:52 PM
Re: Bleeding air
Anybody? Where is the bypass pipe and bleeder screw like you said?
Old 12-16-2005, 03:53 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: Bleeding air
The green cap with the valve on one of your lines, I believe is to recharge your airconditioning.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 12-16-2005, 05:48 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: Bleeding air
You don't need any of that crap, just drive it around and check the coolant for a few days.
CDRU was right, the coolant tank is the highest part of the cooling system, the air bubbles will find their way there and head out through the top.
Those tools are for folks who service someone else's coolant and need to make sure its good to go when they leave the service location.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
