Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 11-28-2005, 04:43 PM
kph kph is offline
Gas smell related to bad repair work??
I had the check engine light come on in my '95 ES 300, so I took it into the local Lexus dealer who replaced the throttle position sensor. A few days later the car started to smell strongly of gas after running for a few minutes while sitting still. Could the smell be a result of something from the new throttle position sensor being maladjusted, or an overzealous mechanic messing something up under the hood? I wanted to know to see if I should try and make the dealer pay for the repairs if it is related. Thanks
Old 11-28-2005, 08:23 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool Re: Gas smell related to bad repair work??
TPS can send the ECU into open-loop mode @ 75-80% throttle, & helps the transmission decide when to shift.
If the TPS is widely defective, it might hurt gas mileage a little bit, but it wouldn't cause that much fuel dumping in.
I would take it back & complain, then never go to a dealer again.
Incomplete combustion. (too little spark, too much fuel)
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
