Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 11-28-2005, 04:03 PM
las3645 las3645 is offline
Unhappy Should I keep my 2001 Trooper?
Hello fellow trooper owners. I bought my 2001 Trooper a little over a year ago. Since then my check engine light has not gone off, I have had my EGR valve replaced, and all the tubbing that goes along with it, it got a 90,000 miles tune-up, and get the oil changed REGULARLY. I just had a check engine diagnostic done on it and it says that the EGR valve is still broke and now the O2 sensors are broke. Not to mention that I am getting only 11 MILES PER GALLON!!!!!! The car almost has 100,000 miles. Should I look into getting everything fixed or trade it in for a more reliable SUV? I just don't want to put money into a car that is going to start breaking down because it has over 100,000 miles.
Any advice is greatly appreciated. (or any advice on the kind of SUV I should buy if I don't keep the Trooper?)
Old 11-28-2005, 04:31 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Re: Should I keep my 2001 Trooper?
How is the idle? Is it running rough? May be your IMG's.
Marc
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 11-28-2005, 04:56 PM
amigo-2k amigo-2k is offline
Isuzu Guy
the 11 miles per gallon could be due to a bad o2 sensor (they don't all go bad, there is a code for each one).
EGR's typically never need to be replaced, only cleaned.
Has an Isuzu dealer been fixing your problems?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 11-29-2005, 11:05 AM
rodeo02 rodeo02 is offline
EGR issues on these engines 90% of the time can be fixed with a $3 can of intake cleaner, some clean rags, basic hand tools and 15min of time. As far as the O2 sensor issues, you have 4 of them. Which are showing a code? Like Marcre says, your air/fuel trim might be off due to a cracked intake manifold gasket also super common. Another thing you might want to consider is a $40 OBDII code reader from harbor freight tools (or the likes). It helps with the DIY diagnosis! Look thru Amigo-2K's FAQ's at the top of the forum main page. Trading in/selling the troop would be horrible, as resale value is nil (especially these days). If I were in the market for a new 4x4 SUV, with no 'zu's avail, I'd probably go Xtrerra, Pathfinder, Jeep, Sorrento or 'Yota if I won the lottery.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 11-29-2005, 03:12 PM
Re: Re: Should I keep my 2001 Trooper?
Marc
It idles really loudly. And when I roll up my windows (its electric) the car idles quieter, but the second I stop messing with the window buttons it sounds like its grinding something. As far as the RPMs go when I idle its probably sits around 1800. Hope this answer's your questions.
Old 11-29-2005, 05:51 PM
Re: Re: Re: Should I keep my 2001 Trooper?
Originally Posted by las3645
It idles really loudly. And when I roll up my windows (its electric) the car idles quieter...
Throw the volume up on the radio, and it will be quieter yet!
G/luck
Joel
Old 12-05-2005, 09:23 PM
GOBOGIE's Avatar
GOBOGIE GOBOGIE is offline
I agree that O2 sensor is a likely culprit for poor mpg
1994 Trooper 226K miles (owned since new)
2001 Trooper Limited 27K miles (in storage waiting for '94 to die)
2001 Explorer Sport 4x4 - Daily Driver
Old 12-07-2005, 11:44 PM
99trooper01 99trooper01 is offline
Fix it and KEEP it! With the help you'll get on this site you can fix it for little cost. If you sell it, you won't get anything for it these days.
