| Let's get Technical! Discussion for hardcore in-depth motor heads! |
removing power steering
ok im done with the power steering and im sure its not that hard to take out but does anyone have a good description of how to remove the power steering, any help would be great
Re: removing power steering
take off the power steering. take the hoses off at the rack and pinion. turn the wheel to get all the power steering fluid out then cap it off at the rack and pinon
y are you taking out the p/s for?
I like my engine like i like my girls D's NOT B's! "I'm not a ricer, i'm a RACER!!!" John D 89 supra N/A 5 speed... SOLD, 97 Neon.. broke down <-- typical dodge 94 300... under construction |
b/c i dont need it, it frees up a tiny bit of hp and it makes engine bay look a lot cleaner looking.
Power steering pumps only take 2-3 hp......loose 20lbs and it'll have the same effect
they know its a tiny bit of power but they said "look cleaner" and i agree it is worth it to look better but unless you have minimum i/h/e its not worth it
i know the hp gains are not high at all like i said but i am more of a person the likes nice looking engine bays.
have fun driving around after that.
96 EJ6. Future home of boosted B18C1.
It's not bad driving a car without power steering. Many civic's that I've had didn't have it. Personally, my 94 ex does have it, and while I do like it, not having it isn't a problem. As for how it looks, I don't mind it sitting there, but to each his own.
I alternate between having my P/s hooked up and having it disconnected.
Yes you can feel a slight difference (even without removing it, I just pull the belt off) But I get tired of it reall quick and hook it back up. See My problem is my P/s pump leaks like a bastard when its hooked up and I can't afford a new one, so when I get tired of cleaning power steering fluid off my engine I disconnect it for about a month, but then I get tired of not having it and reconnect it, and the cycle begins again.. haha. Anyway I wouldn't bother getting rid of it as you never know if you may miss it. try running without the belt for a while to make sure you can live without it. Edit: sorry I'm a little buzzed and just realized that if you don't have a multi belt system this obviously will not work. If you have a serpentine belt system on your car, you will just have to remove it and get a shorter belt to run the rest of your accesories. as long as its new path doesn't interfere with anything.
Old: 1993 Acura integra gs-r New: 1998 chevy BlaZeR2~ AKA "Jeep recovery device" Newer: 2007 Honda CB900F "919" |
