Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 11-28-2005, 01:46 PM
jaguar02 jaguar02 is offline
Radial Arm Bushings
I am in the process of replacing the bushings on my 94 limited. I removed all teh bolts/nuts and I see 2 metal studs holding teh arm to the frame. Do these need to be torched off?
Old 11-30-2005, 08:52 PM
bumpinkicker04 bumpinkicker04 is offline
Re: Radial Arm Bushings
Do you mean the control arms?
Old 12-01-2005, 07:04 AM
Yes, they are the control arms.
Old 12-01-2005, 12:23 PM
Well I will post the procedure straight out of the book tonight. If you still need it.
Old 12-01-2005, 12:51 PM
Yes, I still need it, thanks
Old 12-01-2005, 08:24 PM
There are a few things different depending on if you have a a 4wd or a 2wd. I will note the differences.
Remove the spring assembly. On 2wd remove the spring lower seat from the radius arm. Remove the bolt and nut securing the the radius arm to the front axle and front bracket.
On 4wd remove the spring lower seat and stud. remove the bolts securing the radius arm to the front axle bracket.
from the rear side of the radius arm bracket, remove the nut, rear washer, shield (passenger side only) and insulator.
Remove the radius arm and remove the inner insulator and retainer from radius arm threaded end .
That should do it. Sorry my scanner is messed up so I can't send the pics.
