Old 11-28-2005, 10:52 AM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Question bogging Down
Ok i did do some reasearch on this subject but none of the things that i saw apply to my friends car. My friend bought a 91 talon awd for 1500 dollars. Pretty good deal and its all stock. The only thing is its been sitting for 6 years. We chaned out all of the fluids in the rear diff, transfer case and manual tranny oil. The timing belt looks good and the other stuff is good. I mean we have chaned out everything that we can do at work. Anyway when every you are at full throtle it bogs down between 4500 and 5000 in every gear Any ideas whats going on here. He's supose to race my friend in his TT but we need to fix this problem first. Also he has a bunch of parts to put on but we need to fix this first
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 11-28-2005, 11:06 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Did you put in new plugs and gap them right?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 11-28-2005, 11:30 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: bogging Down
did you change out the gas?? if it's been sitting for 6 years that gas might be kind of shitty. also what |_eclipse_| said
95 Talon TSI AWD
97 Eclipse GST
Old 11-28-2005, 12:14 PM
Re: bogging Down
yeah we did all of that
MODS
Old 11-28-2005, 01:03 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: bogging Down
get NGK BR6's and gap them at .028, get new spark plug wires, they more than likely corroded over time.
If it still bogs look more deeply into the ignition.
now - 2000 civic
soon - 2002 is300
Old 11-28-2005, 02:06 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: bogging Down
Check the TPS to see what condition its in, if thats not the problem try changing the fuel filter.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 11-28-2005, 02:52 PM
Black97GST Black97GST is offline
Re: bogging Down
yeah I would also check the fuel filter, try injector cleaner and flush the fuel system/ fuel tank.
Old 11-28-2005, 04:36 PM
Re: bogging Down
check for boost leaks too
now - 2000 civic
soon - 2002 is300
Old 11-28-2005, 05:41 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: bogging Down
That definately sounds like fuel to me.
When cars sit they tend to get clogs in the injectors/lines and filters.
1991 GSX 2.3 Stroker
Old 11-29-2005, 11:30 PM
Re: bogging Down
changed fuel filter did the fuel injetion fleaning and boost leaks all and i mean all has been done we work at a oil change place so we did every service that we offer to his car
MODS
Old 11-30-2005, 06:41 PM
Re: bogging Down
well we got it. It was the Ecu. Well thats all we could figure so far. He hooked up his safc and the problem is gone now. a t3-60 is bigger than a 16g correct? he has one that he is trying to get rid of but im sure that its bigger than the 16g.
MODS
