Old 11-28-2005, 10:44 AM
Jocache83 Jocache83 is offline
Unhappy questions
i'm trying to paint my celica white (ts26) but it came out to be an off white color... i used masters white primer... any reason why it came out this way?
and my last question deals with air compressors.. what's a decent air compressor that's under $150 US??? whats the difference between a hobby air compressors (badger, paasche) vs a traditional one (craftsmen, etc.)... thanks
Old 11-28-2005, 11:30 AM
Hawk312 Hawk312 is offline
Re: questions
As for you first question, what color is the plastic of the kit? The color of the plastic may be "bleeding" through the paint. This will happen even with primer if the plastic color is "hot" enough. Red is the worst, but I`ve had problems with yellow, blue, and black as well. You might be able to use a primer/sealer to prevent this if this is the case. Advance and Pep Boys carry a primer sealer in a can by Duplicolor. Don`t use Duplicolor on the new Revell kits though, as it will etch the plastic.
As for your second question, can`t help you there. I have always used spray cans!
WANTED! 1/12 Corvettes and Camaros.
Newest builds. Click on images to go to the thread:
1/12th `69 Z/28 Camaro and 1/12 `67 Corvettes
Old 11-28-2005, 11:46 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: i have 2 questions
For your compressors question, use the search. The question has been answered numerous times and will help you find the exact answer to your question.
-Mike
Old 11-28-2005, 12:06 PM
ok, thanks guys.. the body color is silver...
i did my search in the forums and it helped out.. i should use it more often.. well i've been looking around for an aircompressor just now and i saw this, http://www.harborfreight.com/cpi/cta...emnumber=92403
what do u guys think?
Old 11-28-2005, 12:26 PM
gpz900ra7's Avatar
gpz900ra7 gpz900ra7 is offline
That compressor is alright if you just want to paint little parts but, if you want to paint quite a few parts at the same sitting then I would recommend a compressor with a storage tank, that way it only runs when the air runs low, I find they are more controlable, pressure wise.
MY 1:1 toy
Old 11-28-2005, 05:07 PM
how come the badgers and paasches dont have storage tanks?
Old 11-28-2005, 07:46 PM
freakray freakray is offline
AF Modelrater
Re: Re: i have 2 questions
You're probably looking at the ones geared more towards the low volume user, Iwata makes units with tanks.
Bottom line is, you can get a more mainline brand with a tank for close to the same price as a Badger without a tank. And the mainstream one will work if you just set it up with the right add ons.
AF User Guidelines
Old 11-28-2005, 09:25 PM
RallyRaider's Avatar
Zomby Woof
Back to the colour question. TS-26 is not a very opaque paint in my experience. The undercoat has to be very white if the surface is going to pure white. So I'd suggest if your topcoat of TS-26 came out off white then you need further coats of white primer to give it a really stark white base. Dunno what the white primer you used is like, I use GSI Creos Base White 1000 and find it covers extremely well.
