Old 11-28-2005, 10:41 AM
Sp3cops70's Avatar
Sp3cops70 Sp3cops70 is offline
Send a message via AIM to Sp3cops70 Send a message via MSN to Sp3cops70 Send a message via Yahoo to Sp3cops70
shaking problem
please help!! i have 94 honda accord ex v-tech, automatic. i just put a rebuilt motor in it, new motor mounts, but it is shaking when the car is stopped and when i turn on the a/c it shakes even more. while the car is moving it is fine. any suggestions would help.
^^^^CLICK IT!^^^^ ^^^^CLICK IT!^^^^
Old 11-28-2005, 12:38 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: shaking problem
You need to adjust the idle air mixture if there is a screw for it on the throttle body. Turning it out will make it idle smoother. Just go 1/2 turn at a time, stop at the point where it no longer changes the feel of the idle.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 11-28-2005, 12:40 PM
Re: shaking problem
Actually first you need to verify that you aren't sucking air somewhere, intake gasket, vacuum port open, broken vac line, etc.
What I said about the idle mix will compensate, but if there is a leak causing it to idle lean, it needs to be dealt with before adjusting.
...empty gun rack.
