Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-28-2005, 10:32 AM
inatalonIXLR8 inatalonIXLR8 is offline
LUCAS oil stabilizer
I have been running Mobil 1 5w30 fully syn since I bought my car, and have been using Lucas oil stabilizer in it only in the warmer months. I have always felt like it would make the oils viscosity too thick when it gets cold. What do you guys think? Now I'm concidering Royal Purple oil. Does anyone have knowledge about the best oil for our cars, weights and all? How about that racing oil Mobil came out with?
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 11-28-2005, 12:12 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I hear nothing but bad things about adding Lucas oils. I would just stick with the Mobil 1 that you are using, and in the summer months bump it to 10w30.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 11-28-2005, 12:32 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: LUCAS oil stabilizer
i blew 2 engines thanks to lucas oil stabilizer. it's too think and you don't get much flow and it burnt up 2 motors of mine. why are you running it anyways? you shouldn't need to unless your engine is really worn out
95 Talon TSI AWD
97 Eclipse GST
Old 11-30-2005, 04:56 PM
I first started using it because it seem to quiet down my lifter tick. I'm sure you've seen the little demo at every parts store with the gears. As soon as I gave the bottom cog a few turns and seen how the product worked, I began running it in my car. So you really have had two motors go on the stuff? ouchhhh. Do you think it was impeding oil flow being too thick? How much Hp were you pushing?
Old 11-30-2005, 07:12 PM
well the reasons they blew is because the heads burned up because they weren't getting enough oil flow and they had new oil pumps on them. that shit's just so thick that it could keep the head lubricated enough. i was a stock motor so i wasn't pushing any performance numbers in hp. i don't know, i just won't ever deal with that shit ever again.
95 Talon TSI AWD
97 Eclipse GST
Old 12-01-2005, 10:04 PM
Thanks for the heads up guys. Does anyone like the Royal Purple oil? Or has anyone looked into the race oil that Mobil has?
Old 12-01-2005, 11:59 PM
I have heard good things about Royal Purple, but it's relatively expensive and is very fluid-like, so unless your motor is used to synthetic (which obviously yours is), it could make your motor more prone to leaks. Haven't heard anything about the Mobil race oil.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 12-02-2005, 08:52 AM
I think it might just be marketed up here in Canada. Next time I'm in the store I'll check the weight to let you guys know. I always see comercials from the states that shows Mobils 5000 mile, 10 000 mile ect. Yet it's definately not available up here. Test marketing perhaps?
Old 12-23-2005, 07:03 PM
HPNOTIQracing HPNOTIQracing is offline
lucas is no good my boys oil pump couldnt even pump the crap after a few days and it blew it up.
Old 12-24-2005, 09:24 PM
duffman868 duffman868 is offline
i haven't had problem with lucas. i run 20w50 with lucas in my civic with 10w30 in the winter. but i have ran it in my talon yet
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 12-25-2005, 07:25 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Re: LUCAS oil stabilizer
key word there is honda
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
