Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-28-2005, 07:19 AM
kjowings kjowings is offline
Question Oil In Gas
1998 Suburban 205,000 Miles Engine Only 12,000 Replaced Last year.
Yesterday Ran Fine This Morning Went To Start it Won;t. Hard To Crank Pulled Oil Dipstick Smelled Gas. What Could Be Wrong.
Old 11-28-2005, 08:18 PM
2000CAYukon 2000CAYukon is offline
Re: Oil In Gas
A bad fuel pressure regulator (diaphram leaking) or a stuck injector.
The fuel pressure regulator is a very common problem. If you pull the top half of the intake off (the plastic part). You can pull the vacuum line off the regulator. If there is fuel in the vacuum line, it is leaking and needs to be replaced.
If is not leaking, then the injectors should be tested.
//2000CAYukon
