Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 11-27-2005, 11:53 PM
OrToy OrToy is offline
Send a message via MSN to OrToy
I turn the brake off but its light still stays on...
Okay, Question:
I've got a '95 Toyota pickup w/the 22re engine in it and I've got a few problems. The biggest one right now is that the emergency brake light stays on after I turn it off and it comes on sporatically while I'm driving. I can't figure out what is wrong with it on my own, so, does anyone else have that problem? Do you know how to fix it?
Next, I have a wierd squeaking noise coming out from under the hood. I changed all of the fan belts but it still won't go away. I know that there's a lot of stuff down there but what else could it be?
Lastly, my hood rattles and I can't figure out how to get it snug. I know that the hinges need to be tightened but I can't get to them. How do I do it?
Thanks to anyone who helps out...
Sean
Old 11-28-2005, 03:33 AM
KimMG KimMG is offline
AF - Advisor
Re: I turn the brake off but its light still stays on...
Check the brake fluid level.
Old 11-28-2005, 09:46 AM
Re: Re: I turn the brake off but its light still stays on...
Thanks, I thought that it was something mechanical
Old 11-28-2005, 12:03 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
If it's not the fluid level, it the switch on the parking brake may be sticking.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 11-28-2005, 09:44 PM
I checked the brake fluid level and it is fine, but the light still is problematic. Where is the switch on the parking brake?
Old 11-29-2005, 02:15 AM
AF - Advisor
How many miles are on your brakes?
Old 11-29-2005, 09:52 AM
I don't know exactly, but I know that I need to change them soon. I didn't know that could contribute to the parking brake light.
Old 11-29-2005, 11:48 AM
fourwd1's Avatar
AF -Advisor
As the pads wear it takes more fluid to move the caliper, so fluid level goes down in the MC resevoir, triggering the light.
There is a switch under the dash, hooked to the rod that is turned when you apply the parking brake.
89 4Runner - stock
Old 11-29-2005, 03:46 PM
Is there anything I should know before fiddling with it? What should I do first, replace the brakes, or flip the switch?
Old 11-30-2005, 09:39 AM
fourwd1's Avatar
AF -Advisor
First locate the switch on the parking brake rod assembly.
Then release the p brake. If the dash light is still on, fiddle with the switch to see if you can make it go out.
If the MC fluid level is OK, it could be the float switch in the cap is flakey, but that's unusual. You could fidle with the float switch to see if you can make the light go out.
89 4Runner - stock
Old 12-06-2005, 11:24 PM
I wish I knew more about this, it's my first truck.
when replacing the brakes do you have to take the truck to an alignment shop, or can you do it yourself?
Old 12-07-2005, 02:47 AM
AF - Advisor
Buy a repair manual or go to your local library and see if they have one. Read about how to replace your brake shoes and pads. Become familiar with all the parts pictured. Then decide if you are up to the job. The braking system is the most important safety system on your vehicle. If it fails, you could kill or maim someone or yourself.
As a student you may be able log on to the school library through your school's home page. Some schools and libraries subscribe to online databases that have vehicle repair manuals.
Old 12-07-2005, 06:36 PM
Thanks, I got that much.
The brakes were the problem, they were pretty much down to the nubs.
Does anyone else know about any of the other problems previously posted?
Old 12-08-2005, 10:18 AM
Don't worry I'm taking it to a shop. I just needed to know what the problem was. I can do the brakes and pads but I need to get the rotor tuned up. They aren't scored, they just need to be set.
Old 12-13-2005, 03:34 PM
Does anyone know how to fix the hood problem. I can't figure out how to get to the hinges. There's a rubber seal where the hood hinge arms go into the firewall, but no udjustment bolts or screws.
