Old 11-27-2005, 10:39 PM
newbicivic89 newbicivic89 is offline
Engine swap
I got a D15B2 stock engine in now i want to swap it out with a D16Y8. I want to know what will i have to change like harnesses or anything like that.
Old 11-27-2005, 11:21 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Engine swap
dude i thought you had a b18c
Team Lonely Drivers
Old 11-28-2005, 05:43 AM
Hybrid1990crx's Avatar
Re: Engine swap
you'll have to wire over to mpfi, which means getting a resistor box, and wiring in two more injectors.
Or if you want to be real clean about it, you can get a si engine harness, and si interior harness and do a full swap over. but thats usually more costly and a bit more work to do, but its what I would do if I was converting to mpfi.
other than that, youll need to do a cable to hydro conversion if you are using the y8 trans, if not I sudjest getting a 89-91 si trans and the clutch to match the trans.
youll also need to convert to obd2. if you choose not to, you can use a pm6 ecu and dizzy, but then you'll have to engage vtec with a controller, or a rpm switch.
Old 11-28-2005, 08:05 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Engine swap
You can use a Y8 and convert to OBD1 (even though the engine is from an OBD2 car). Check www.rywire.com for mpfi/vtec conversion harnesses. OBD1 ecu for sohc vtec is p28. Search and read.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 11-28-2005, 09:55 PM
kingpinn's Avatar
kingpinn kingpinn is offline
Re: Engine swap
or you can use the " Search " and save everyone time
"Much to success to ya, even if you wish me the opposite;
Sooner or later we'll all see who the prophet is" Nas
