Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-27-2005, 10:03 PM
bjmm's Avatar
bjmm bjmm is offline
Send a message via AIM to bjmm Send a message via Yahoo to bjmm
Question 1995 talon esi engine swap
I have a 1995 talon esi (2wd) with a bad engine. I need to know what engines will replace it. will it accept turbo and AWD engines? also what is the differance bettwen a 6 and 7 bolt engine?
Ben Modic
aka
Modic
aka
Bmod
Old 11-27-2005, 10:14 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 1995 talon esi engine swap
The 7 bolt crankwalks more frequently and the 6 bolts came stock with beefier internals. The only engine it would be realistic to swap in is the 420a, just what you have go in there now. The turbo engines would be a tough swap and would cost a lot. This topic has been covered thoroughly, you should try a search before you ask a question. BTW, welcome to AF.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-27-2005, 10:22 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Not trying to be an ass, but if you have to ask that question an engine swap is not for you.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 11-27-2005, 10:30 PM
bjmm's Avatar
Re: Re: 1995 talon esi engine swap
thanks Thor06.
whats wrong with learning ez1286?
Ben Modic
aka
Modic
aka
Bmod
Old 11-27-2005, 11:17 PM
ez1286's Avatar
Re: Re: Re: 1995 talon esi engine swap
Originally Posted by bjmm
thanks Thor06.
Nothing. I said i wasn't trying to be an ass but 90%+ people who say they are gonna do a swap of a 4g63t into a 420a car never do it based on the price of everything and all the work involved. If your gonna do it more power to you, and good luck.
Old 12-01-2005, 09:31 PM
inatalonIXLR8 inatalonIXLR8 is offline
You should source out engines at wreckers. You'll find the 420A engine in 95-98 Eagle Talons non turbo esi, Eclipse RS and GS, Avengers, and Sebrings. You can get a better price if you tell the wrecker that you are calling from a repair shop and the engine is for a customer. Just make sure you O.K. this with the shop that you are going to get the swap done at in case they decide to call. I'm doing the exact same thing to my girlfriends car right now. Expect to pay $1000 Canadian for an engine with120,000 km, $1200 for 100,000km. Usually with a three month waranty.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 12-01-2005, 11:06 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Damn you Canadians. LOL. 1000 Canadian... 100,000km... what the hell?!?! Just joking man... love all around.
A basic engine swap will probably cost more than just selling it and getting a new car. Or pull it and fix whatever is wrong with it. What's the problem?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-02-2005, 11:39 AM
The Talon Esi I bought for my girlfriend has what sounds like to me, a loose wrist pin or the piston skirt has gone, or maybe the rod on the crank. Yet it still runs strong. So after I bought it I drove it home and parked it since. It's fairly quiet up to 1500 rpms, metal slapping sound between 1500 and 2000, goes quiet again after but I never pushed it past 2500 rpm. (420a motor)
Old 12-02-2005, 12:10 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
i wouldn't drive it anymore until you figure out what the problem is...you might just be saying goodbye to a motor.
95 Talon TSI AWD
97 Eclipse GST
Old 12-02-2005, 05:31 PM
Ya, I haven't even started it up since I got it home. Any ideas from what I've said as to what the problem might be? How much clearance is there between the valves and piston on the 420a motor? It sounds as if there is nothing wrong with the head. Got my fingers crossed at least.
