Old 11-27-2005, 08:09 PM
laxman21's Avatar
laxman21 laxman21 is offline
Distributor replacement
Need directions on proper way to replace distributor.
I know which one to get. I have it removed and indexed marked the engine for proper installation.
Do I need a new gasket and O-ring?
Do I need to grease/oil the gears before I install it?
92 4.3 z engine
Old 11-28-2005, 05:41 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
You will need a new dist gasket (about 50 cents). You can use your finger to rub a little oil on the gear if it makes you feel better, it's really not necessary. Drop it back in on a smiliarly marked path as your old one.
Disconnect the ecm wire behind your passenger side carpet (tan wire) Start the truck, time it to 0 degrees TDC, then lock the distributor down. Time again to make sure all is good, then reconnect the wire you disconnected. Drive, be happy...
