Old 11-27-2005, 07:56 PM
JFLS40 JFLS40 is offline
2001 Ignition Wire Diagram
Can someone tell me the ignition wiring diagram for a 2001 Grand Caravan? I am trying to hook up a remote starter-keyless entry and the installation instructions that came with it doesn't match my vehicle.
These are the actual wire colors I have coming from the key switch.
light blue w/brown stripe=
yellow=
2 pink w/white stripes=
purple w/black stripe=
purple w/ orange stripe=
Thanks for your help.
Jeff
I would appreciate it if you could email me at [email protected] with the answer.
Old 11-28-2005, 07:08 PM
B33p3r B33p3r is offline
It's on the way
Old 11-29-2005, 09:37 AM
Re: 2001 Ignition Wire Diagram
Thank you for sending the schematic, it is exactly what I needed. Can you help me with figuring a couple of things out? I tried to call tech support but 8 people in line waiting and I don't have the time to sit on the phone.
From my directions, I have 4 wires to hook up. Blue, Green, White and Yellow. The directions say the Ignition 1 in the car is BLUE, Ignition 2 is DGRN/RD, and the ACC is BLK/OR. I don't think this is right. Here is how where I am at with this...
1. Blue wire to Ignition 1. Should measure +12v with key in Start and Run and off in Lock/Off and Accessory. I was going to hook this up to the PK/WT wire.
2. Green wire to Ignition 2. The Ignition 2 wire measures +12v in the "Run" position and is off (ground) in the Lock/Off and Accessory position. In certain vehicles, it may also show +12v in the Start position or Ignition 2 may turn Off during Crank and turn back On after the starter disengages. I am not sure if the Green wire should hook up to the PK/WT or the VT/OR?
3. White wire to ACC which is +12v in the Run and ACC position but OFF in the Start and Off positions. Should this be hooked up to the VT/OR?
4. Yellow wire to Starter. This is easy, hook up to the YL wire going to the starter.
Remote Starter Ignition Key Diagram
Blue (Ignition 1) PK/WT
Green (Ignition 2) ?
White (ACC) VT/OR
Yellow (Starter) YL
Any help is greatly appreciated.
Old 12-21-2005, 08:14 AM
linsook linsook is offline
could i get a copy off the diagram aswell please?
