Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 11-27-2005, 07:55 PM
White_Beast98 White_Beast98 is offline
Lightbulb Changing Front Strut
I am wanting to learn how to change my front struts but all of the spring compressors that I have tried have all failed me. Has anyone ever done this at home? if so can someone send me a picture of the correct spring compressor to use if i need a compressor to change out the front struts. I refuse to take it to a shop when I have the will to learn and do it my self.
Old 11-28-2005, 02:57 PM
baron1701 baron1701 is offline
Re: Changing Front Strut
Im All About Doing The Struts Yourself. From What I Understand, There Shouldn't Be Much To It. As To The Compressor I Would Like To Know Myself.
I Always Thought That A Manual Compressor Fit Universally.
Old 11-28-2005, 08:21 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Re: Changing Front Strut
I Always Thought That A Manual Compressor Fit Universally.[/quote]
That is correct. Most cheap ones are two-piece units, like a long bolt with steel teeth on each end.
Quality isn't expensive, it's priceless.
Old 12-04-2005, 01:33 AM
kiway22 kiway22 is offline
Send a message via Yahoo to kiway22
Re: Re: Re: Changing Front Strut
The strut compressors I have seen. Are a set of 2, where 1 go on each side of the strut spring. And you tighten each one compressing the spring.
Old 12-04-2005, 01:58 AM
Indy8's Avatar
Re: Re: Re: Re: Changing Front Strut
That's the ticket! Made in China, $20 at most stores. For occaisional use only.
Old 12-06-2005, 09:59 AM
billysandra billysandra is offline
I need to program a keyless remoye for my 1995 Olds Aurora. can anyone help me?
Old 12-07-2005, 09:09 PM
zimaad zimaad is offline
If you have an Autozone nearby, you can get a loaner. That is what I used to do mine. Just the basic universal type...couple of clamp/collars and long bolts. Make sure you have a factory manual or subscription t alldata to get the correct torque specs. Then, make sure you get it aligned.
best of luck....
