Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 11-27-2005, 08:28 PM
baggedranger10 baggedranger10 is offline
Send a message via AIM to baggedranger10
want to make my rear go lower!..need help
hey i have a 96 bagged ranger.. the front completly lays out.howveer.. the rear goes pretty low.. but not as low as i want it to go. i wanna be able to drag. when i sit the hole back end down.. its not even rubbing the wheel well. what could i do to make it go lower?
Ryan
Old 12-17-2005, 02:46 AM
maestrojv maestrojv is offline
Re: want to make my rear go lower!..need help
change leaf spring shakles to ones that will seat the rear end lower, change leaf springs to ones with a lower profile (less arc) or you could go whole hog and customize your frame, but thats a big big job. Some rangers come with a highrider package and the rear leaf springs may be seated on a 3-4 inch lift block... if that is the case you can remove that also.
Life is a work in progress...
Old 12-17-2005, 10:48 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
you can only go so low before your rear diff will hit the underside of the bed. then you will have to cut a hole
Old 12-17-2005, 04:54 PM
Marbles1984 Marbles1984 is offline
Mudder is right. You will probably have to notch the frame to get it to pancake.
