Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 11-27-2005, 08:19 PM
TRA RIV TRA RIV is offline
Eng Tapping Not Valves Or Lifters
I HAVE 87.000 MI ON MY AURORA ,I WAS TOLD IT SOUND LIKE THE TIMING BELT TENSIONER OR A CRANKSHAFT BEARING THE TAP COME AND GO. I PURCHASE THE CAR IN AUG 05 THE CAR LOOKS NEW INSIDE AN D OUT AND RUNS GRATE (HELP) ENG DIAGNOSTIC SAID BAD LIFTER ON # 8 CYLINDER WHAT WILL IT COST TO FIX MY 1999 4.0 ENG
Old 12-02-2005, 02:01 AM
bradan bradan is offline
Lightbulb Re: Eng Tapping Not Valves Or Lifters
What year? my 95 has similar noise+ a few others, possible answers?
Old 12-03-2005, 07:53 PM
Re: Re: Eng Tapping Not Valves Or Lifters
1999 is year
Old 12-04-2005, 02:51 AM
Indy8's Avatar
Indy8 Indy8 is offline
Engine has good 'ol fashioned timing chains, not belts. Not sure if there are even lifters on these or not. With some overhead cam designs the lobes directly lift the rocker arm and the other end of the arm contacts the valve stem, but these type need periodic adjustment. If the noise was main or rod bearing it would get worse real quick.
Quality isn't expensive, it's priceless.
Old 12-07-2005, 07:39 AM
ckpaas ckpaas is offline
Are you using 91 octane or higher fuel? The high octane requirement is so a pre-detonation doesn't occur. The pinging could be just that (pre-detonation) which is the cylinder firing when the piston is on the up stroke.
Old 12-07-2005, 06:28 PM
THANKS FOR THE INFO
Old 12-07-2005, 06:37 PM
Re: Re: Re: Eng Tapping Not Valves Or Lifters
YES 91 AND HIGHER OCTANE AT TIMES THANKS FOR INFO
Old 12-08-2005, 01:22 PM
Would that apply to '95 w/ 100,000 m? If so, how do i go about that periodic adjustment?
Old 12-09-2005, 03:35 AM
Indy8's Avatar
Hydraulic lifters 'pump up' with oil at start-up and operate in a zero lash state keeping in constant contact with the valve and rocker arm. Someone in this forum who has had the valve cover(s) off their engine would need to confirm that they are in fact hydraulic. Engines are now designed to be no maintenance so I really don't think they would be the flat tappet style. GM has used hydraulic since the 50's.
Old 04-08-2006, 07:38 PM
help me if you had the vavle covers off, are there rocker arms or cams followers.
