Old 11-27-2005, 05:23 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Unhappy Code 26
Hi i have a 93 z28 camaro and the check motor light came on so i got it checked and it is code 26, the quad driver module. Does any one know what causes this to come on or how to fix it?
Old 11-27-2005, 05:56 PM
97cavalier's Avatar
Re: Code 26
Ok so i was checking this out and the car does not run any diffrent so some peole are tell me that it is probly the evap purge silonide. Does this sound right?
Old 11-27-2005, 09:27 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Code 26
Yes, that code is for the Evap purge solenoid and I would start by checking the wiring harness for any damage to those wires.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-28-2005, 12:29 AM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: Code 26
replace the solenoid and get rid of the canister and vacuum lines too. plug em.
Old 11-28-2005, 09:03 PM
97cavalier's Avatar
Re: Re: Code 26
Why get rid of it?
Old 11-28-2005, 10:55 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Code 26
Your better off checking the wires before replacing the solenoid, the evap solenoid is pretty rare thing to go and if you replace the solenoid to find leter it was just a fried wire your not going to feel too bright (trust me, I've been there).
Old 11-29-2005, 06:12 PM
97cavalier's Avatar
Re: Re: Code 26
Where do i check for burnt wires? Under the dash?
Old 11-30-2005, 10:40 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Code 26
You know where the evap solenoid is right?
Start there and then check continuity from the PCM pins to the harness connecter. If there is a problem with one of the wires just traces it back to the PCM til you find the problem. Although most likely if there is a problem it will be at the connecter clip.
