Old 11-27-2005, 11:57 AM
squibly7 squibly7 is offline
93 taurus brakes
I have replace the drums/shoes/cylinders and front pads on my 93 Taurus wagon. I am able to bleed the brakes in proper sequence and get a nice firm pedal with the engine off, but as soon as I start the eng. I get brake travel all the way to the floor. After engine is shut off the firm pedal returns. Anyone know what might be happening??
Old 11-28-2005, 03:28 AM
KimMG KimMG is offline
AF - Advisor
Re: 93 taurus brakes
Did you adjust your rear brakes to the point where there is a slight drag when you turn the drums?
Old 12-02-2005, 10:39 AM
Re: Re: 93 taurus brakes
Yes I did.
Old 12-02-2005, 04:52 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
You may still have air in the lines. Do you plan to bleed the brakes often (yearly like we're supposed to)? If so, I'd suggest installing a set of speed bleeders on your car. They usually run about $24 for all four corners and the chain parts stores usually stock them. With speed bleeders, it is very easy to properly bleed your brakes and get all the air out. I'd suggest trying to bleed your brakes again making sure to keep the master cylinder full.
Also, you may want to cycle the ABS pump a few times to get the fresh fluid into the pump.
-Rod
