Old 11-27-2005, 11:19 AM
mld mld is offline
t&c transmission 1996
tranw would slip out of gear then back in no codes with key, dealer said it was dead (DONT TRUST THEM) Droped pan, a little bit of fileings in it I've seen worst, I was going to try and flush out system and clean sensors what do you think
Old 11-27-2005, 12:37 PM
Vats Vats is offline
Re: t&c transmission 1996
Dealer told me 2 years ago my tranny was toast, turned out to be the soleniod pack. I know from experience if the sensors get metal filings on them they act up and cause problems without necessarily showing a trouble code. Have you replaced the solenoid pack before and how old is the tranny?
Old 11-27-2005, 09:37 PM
mld mld is offline
Re: Re: t&c transmission 1996
I removed the pack to check it out, cant see much and I dont want to open the pack it self. Don't know for sure how old only had the van one week. I plan on removing the sensors to clean them up when I flush the system
thanks
Old 11-27-2005, 11:00 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If it is doing that there is code someplace.
Get it on a good eng/trans capaable scanner and check it out. A good trans scanner has a lot of info on the trans and will show code history or present.
Get code no and post back codes.
MT
