Old 11-27-2005, 09:02 AM
CollinHartwick CollinHartwick is offline
95 Escort - Heater Problem
Hello,
I have a 95 Escort. The heater seems to be acting wired. The blower works fine but some times it blows hot air like a normal heater should and other times it blows a mix of warm and cool air together and some times it jsut blows cool air. My A/C works fine but this heater problem is a real pain, I need heat in my car I live in canada and winters a fricken cold.
Collin
Old 11-27-2005, 09:09 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Don't know your level of expertise but this is a symptom of being low on coolant. Look in the radiator and make sure it's full. I'm not talking about the coolant reservoir. Actually look in the radiator and see what you have.
Nevada Tumbleweed
Old 11-27-2005, 11:00 AM
J-walk J-walk is offline
Re: 95 Escort - Heater Problem
when u r doing this make sure that u have not ran the car in the last 20 - 30 min or u might get burned the radiator is pressurized
Old 11-27-2005, 11:30 AM
Re: Re: 95 Escort - Heater Problem
Good point J-WAlk! I have some scars from an overheated engine. Tooke the radiator cap of a 1981 Olds Cutlass DIESEL that had a blown head gasket. Looked like 'Old Faithful' when it blew. Had 2nd degree burns on my left torso. Was out of work for two weeks. Ouch!!!!
Of Topic. Have you heard of REO Speed wagon? "REO" stands for 'Ransom Eli Olds', maker of the Oldsmobile. Speedwagon was a truck.
Good trivia question to amaze your friends!
Nevada Tumbleweed
Old 11-27-2005, 03:20 PM
Re: Re: Re: 95 Escort - Heater Problem
thanks man ill use that. by the way do u have the ANSLE (or what ever it is called) system it always seams like u have all the answer and the diagrams
Old 11-27-2005, 05:43 PM
I have a Haynes manual, scanner and digital camera. (Anda lot of time under the hood of my Escort!)
Nevada Tumbleweed
Old 11-28-2005, 01:14 PM
do u have the GT?
