Old 11-26-2005, 10:31 PM
newbicivic89 newbicivic89 is offline
Ticking noise
When i first turn my car on it makes this ticking noise. Its my valve springs dose anyone know how i can stop that noise besides getting another head.
Old 11-27-2005, 12:11 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Ticking noise
add oil might help that or take off vlave cover and get a feeler guage and tighten them to spec and see what happens then let us know....
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 11-27-2005, 12:36 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Ticking noise
i would adjust the valves
Team Lonely Drivers
Old 11-27-2005, 02:26 PM
Re: Re: Ticking noise
How would i do that.
Old 11-27-2005, 05:03 PM
Re: Ticking noise
the one tihing i forget is, is the motor suppose to be cold or warm. can someone find that out cause i dont got my book with me
1 get a feeler gauge
2 find the specs
3 put the feeler gauge to the specs
4 loosen the tightening nut so you can turn the screw up and down to adjust the height.
5 slide the feeler gauge in between the rocker arm and the valve and tighten the screw until you feel a slight drag on it
6 then tighten the nut down to lock it at that height. torque it if you want
Team Lonely Drivers
Old 11-27-2005, 05:25 PM
where do i buy a feeler gauge and how do i find specs
is the feeler gauge just for my car 89 civic or just a feller gauge in general.
Old 11-27-2005, 05:49 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
The engine is supposed to be cold. do it sometime when you havent driven it for hours, or first thing in the morning.
A feeler gauge is just a bunch of thin strips of metal. each strip has a number on it like .020, .0062...etc thats the thickness of the strip itself. It probly only costs a couple of bucks at your local hardware or automotive store. The retaining nuts are 12mm, use a box wrench so you can tighten the nut while holding onto the screwdriver making sure it doesnt move back out of spec.
The specs (this is for a sohc zc, im sure its exactly the same for your engine, i'd be amazed if its not) are:
Intake valves: .007-.009" (.17-.12mm)
Exhaust Valves: .009-.011" (.22-.27mm)
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 11-27-2005, 06:04 PM
Re: Ticking noise
OK well do you know any websites that have pictures of this cause i get what your saying just dont want to go out there and ripp it all apart and then mess up.
Old 11-27-2005, 11:15 PM
Re: Ticking noise
do you know what the rocker arms are? do you know what the valves look like? if you know what both of those look like then you should see what we are talking about. try and look at it first
Team Lonely Drivers
Old 11-28-2005, 02:20 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
This is for Dohc ZC.
http://www.thezcr.com/assets/images/zcbook/1-9.jpg
Not difficult at all just takes a little bit of time. GL
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 11-28-2005, 04:30 PM
well just to let you know i had to replace the headgasket. And get my head shaved. so yes i do know what it looks like. i did it all myself and it runs good still making that noise like before though
Old 11-28-2005, 06:02 PM
Re: Ticking noise
lol that wasnt smart if you have ticking noise...just a waiste of money now...
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 11-28-2005, 08:34 PM
well if you blow the headgasket and warp the head then am i spose to just drive like that aaaaaaaa..... no so i replaced it.
Old 11-29-2005, 03:55 AM
Re: Ticking noise
dude your wasting money on a motor probably isnt worth fixing what I am saying...better to just drop in a new motor of any d series depending on your budget
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 12-02-2005, 01:10 AM
sblkcamaro70 sblkcamaro70 is offline
make sure when you do your valve lash adjustment, that the piston is TDC on the compression stroke for each cylnder you do.
