Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 11-26-2005, 10:44 PM
chubbygoatboy chubbygoatboy is offline
1990 Dodge Spirit speedometer not working
Anybody got any ideas on how to troubleshoot a speedometer not working on a 1990 Dodge Spirit? Is there a component that usually fails on these that would cause the speedo not to work? Any ideas are greatly appreciated!!
Old 12-04-2005, 11:16 PM
bernerfan bernerfan is offline
Re: 1990 Dodge Spirit speedometer not working
Hi
Had exactly the same problem awile ago. In my case, it was the speed sensor on the transmission which had to be replaced. Probably the same situation for you. If the daytime running lights don't come on when you move the car a short distance, it's likely the speed sensor. Quick, simple job to replace. Cheers
Old 12-08-2005, 02:42 PM
Re: Re: 1990 Dodge Spirit speedometer not working
THANKS!! It definitely was the speed sensor. About $40 and pretty darn easy to do. This one was on the trans housing, just above the right drive axle. One 10 mm bolt, and it is out!! The only problem was it took Advance two trys to get the right one, and when they got it, it had the little plastic gear retaining thingys broken. So I ended up at Autozone, whom I hate!! But they had it in stock!! THANKS AGAIN!!
Old 03-08-2006, 07:06 PM
hoosierdaddy30 hoosierdaddy30 is offline
Send a message via Yahoo to hoosierdaddy30
Exclamation Re: 1990 Dodge Spirit speedometer not working
hey, i was wondering if your tachometer was working also. My tach, speedo, and radio doesnt work. This sucks. I've tested radio and it works when i plug it into me other dodge car. but doesnt work in mine. with the speedo and tach not working. no clue
Old 03-13-2006, 01:58 PM
ozzman87 ozzman87 is offline
have you checked all your relays and fuses. almost sounds like something electrical since all 3 of those thing are down.
