When do you consider a cav dead? 200k?
Just curious, how long will you keep your cav? Miles? year?
I got a 92 with 115K. Would like to get 200K. is this blasphemy? |
Re: When do you consider a cav dead? 200k?
If you maintain it well it should make it 200k. I am going to sell my Cavy just because I want a new car and my brother is going to need to get his first car soon. If I were to keep it until a certain milage, I would get rid of it at 100k. Then its still got plenty of life left for the next person. I probably wouldnt keep a car past 150k, but thats just me.
Re: Re: When do you consider a cav dead? 200k?
the HG's are suspected to go around 200KM... my buddies went at 170KM just mantain it and hope you dont got a lemon.. some cavy's are tough. but I seen some pretty junky ones. but, you should get 200K out of it if it wasnt abused and oil changes done regularly. |
Mines at 215k km's or 135k miles, it still runs actually pretty well, keep oil changed etc, but normal clunks and annoyances.
![]() The New Ride!! 2002 Cavalier Coupe.. ![]() Quote:
I still have my 89 with 300k on it. I use it as a spare car now and the car is dying around the motor/tranny. I always go close to 10k on an oil change(abuse?). The original fuel pump just died. And I did have the Headgasket go bad at 200k like everybody else. I think I just keep fixing it to see how far it will go before it needs a major overhaul. I figure it sure isn't worth much now (300k=maybe50$)???
![]() Yes, I am retarded. |
Ill run mine til it dies. Then Ill buy a new motor and run it til it dies. And so on...
MAKE ART, NOT WAR |
I had 2 J-body cars before my 2002 Cavalier base model and I got rid of both of them at 150,000 miles. Both ran well with no major problems at all. Mostly just maintenance. I saw no reason why either car couldn't make it to 200K. Just do your regular maintenance like oil changes, trans oil and filter changes, and personally I drain and refill antifreeze with 50/50 mix every year. That's pretty much all I do.
im with kustm, my cav is at 310k km's and im coming into an engine with just over 200k km on it so ill switch it to that and run it till it dies (for 50$ i figure might as well)
i am at 182,000 on my 2000 cavalier. Still runs. Is it as strong though No
My 94 RS has 165k with no major problems. You have to remember if you take care of your car up front and continue it can last forever. Maintenance being the key word. And yea i have had to replace ignition module,struts, shocks, tires, rotors, brakes, wheel bearings, cat etc, all maint parts and all go bad at some point in time. I change my oil at 3000 miles religiously, already took care of major tune up, and trans tune up, cooling system etc. I bought this car 2 years ago for $400. the cars body will rot before anything else!( central NY winters are a bitch) all in all i love this car!!!
i have 272,000 km on my '92 cavalier. Original engine, doesnt burn any oil. Second tranny though...
![]() Yes, i'm new to the car world. No, i'm not dumb. Add Yourself To The Map AF Members! |
Re: Re: Re: When do you consider a cav dead? 200k?
2001 Toyota Celica GT Check out my CarDomain at... http://www.cardomain.com/ride/2493960 |
My cavalier is an 01 and it has 87k. But I bought it used with like 79k.
