Old 11-26-2005, 07:34 PM
edsel edsel is offline
how to remove coolant bottle?
ok before i break anything what do i do to remove the coolant bottle without breaking it? is there a plastic connector or do i just keep prying it up from the frame where it is connected? thanks again edsel....i have a 1997 astrovan and i am trying to check the fan relay connection behind the bottle...thanks!!!
Old 11-28-2005, 07:49 AM
drew300 drew300 is offline
Re: how to remove coolant bottle?
It's been a while, but I think mine has plastic "rivets" that i pulled the center up, then the whole rivet. Then the bottle lifts out, with long wires and hoses connected.
If you're trying to fix the blower high speed, I found a printed wire on the relay board was corroded away, and replaced it with a soldered in wire.
Old 11-30-2005, 03:26 PM
TrueLyFE's Avatar
TrueLyFE TrueLyFE is offline
Yup, it's an easy removal - just did this on a '97 with a dead blower motor. Just be careful with the washer fluid pump and it should come out with minimal force.
'93 Dodge Caravan, 3.0L, A670 - It runs.
'85 Chevrolet Camaro Z28, 305 HO, T-5 - Transmission died! Parked for repairs.
'87 Buick LeSabre, 3.8L - RIP. Lots of blood, sweat, and tears.
