Old 06-01-2002, 02:19 AM
EF9Civic EF9Civic is offline
Send a message via Yahoo to EF9Civic
B16a
I just put a fuel pressure regulator on my car and gauge and it just turns over it fires but just turns over like it not getting any gas but the gauge is reading that there is gas would putting that stuff get air in the line and just readpressure and not get fuel to fuel rail or what im stumped need a little help pleeeeez
Hope on the rice boat and get you some nawws!!!!
Old 06-01-2002, 09:43 PM
shatshadarach shatshadarach is offline
if you try to start it and right after, open your gas cap, then loosen the service bolt on your fuel filter, there should be some fuel come out of it...
Old 06-02-2002, 02:24 PM
well i got it running and it idles rough and if i hold the gas at bout 3k it stutters would it be cuz the ECUis reading code 14 the IAC
Old 06-02-2002, 08:47 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Take off the Fuel pressure regulator.
I garuntee it will fix the problem.
Old 06-03-2002, 01:16 AM
i cant its the B&M you have to cut a 1/4" off the top of the stock one and put the B&M on top of it you dont think the IAC would do it and is there anyway to idle it down besides the throttle cable
Old 06-03-2002, 01:25 AM
Moppie's Avatar
Master Connector
It sounds like you've got the FPR set way way wrong!
especialy since the problem started only after you put it on, and it sounds like its fuel related.
If you took a stock pressure reading before adding the FPR then set the FPR to that.
If not then set it to about 14psi and hope that works long enough for you to get to a dyno and get it tuned properly.
This is the only way to set it!
Otherwise the idle is essentialy controled by the ECU, and messing with it can cause more trouble than I feel you can fix.
However,if you really want to risk screwing up your engine there is a small brass screw in the Throttle body.
Its above the intake, and is a Flat head screw driver type.
You can turn it in or out to set the base idle speed. but if you get it wrong be prepared for your car to either run to rich, or to dangerously lean out.
Otherwise any other problems require either replacing the cold idle control on the firewall, or the whole throttle body which contains the IAC.
Old 07-08-2002, 11:20 PM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
I had this problems but it wasn't because I put a FPR on it. Check your vaccum lines if you fooled with them. There should be a inline check valve it one of the lines on top of the intake. Pull that vaccum line of. If it runs fine replace the check valve. Too much vaccum the the one peice will make the engine very high or weird but if you were putting a FPR on and it worked fine before you put it on then its obviously what you did.
VTEC WORKING FINALLY & HAULIN SOME ASS!!
If the shadow of your car is smokin' you it definately means you are smokin' someone else!!
KKK k24 Turbo on the way to the install!
