Old 11-26-2005, 04:57 PM
karll's Avatar
karll karll is offline
Send a message via AIM to karll
off road rigs as daily drivers
Whose off road rig also qualifies as their daily driver? I have been wanting to start rebuilding my old 77 c10 into an offroad right, but I don't know if i should because i don't have another car to drive. Who drives there rig on the roads as well as the trails?
Old 11-28-2005, 12:09 AM
Andydg Andydg is offline
Re: off road rigs as daily drivers
I don't have one personally but I know A LOT of people that do and they drive them daily. Some of them have weekend warriors that are built pulling trucks for competitions. My one friend drives his '86 3/4 3 speed every day even with the 33's and the ZZ4...in fact he's upgrading to 40's with a 10 inch lift and he plans for it to still be his DD.
Old 11-28-2005, 02:19 PM
ECVcrawltoy711 ECVcrawltoy711 is offline
i daily drive my toyota with a soild axle swap, dual cases on 37s soon to be 40s. over 40k miles on it like this its nice oh yeah locked front and rear and i live in the snow
Drew
Old 11-28-2005, 07:53 PM
Re: Re: off road rigs as daily drivers
Drew
How long do you're tires last if you're locked in the front?
Old 12-06-2005, 02:02 AM
they last a while its an arb and i dont drive with my hubs locked. i am about to 30k miles on my MTRS now
Old 12-06-2005, 07:39 PM
karll's Avatar
i dont even know what any of that means.
Old 12-06-2005, 07:49 PM
karll's Avatar
Old 12-06-2005, 09:43 PM
Re: Re: Re: off road rigs as daily drivers
Basically he's saying he has an ARB Air Locker in the front which is a selectable locker. Then he has manual hubs for using 4wd anyways so even if it was in 4wd and the Locker was locked, only the back wheels would be putting any power to the ground. This way when he takes a turn he won't be hoppin' all over the place fuckin' up his tires since when you turn the outside wheel must go faster than the inside. Same with the rear tires but the difference in speed is much less.
Old 12-07-2005, 12:41 AM
what do u mean the difference in speed is less for the rear. my rear is usually always locked and the tires just chirp a bit no big deal
Drew
Old 12-07-2005, 08:09 PM
macdad626 macdad626 is offline
2002 Wrangler 4 In Lift 33's Super Swamper Thornbirds And My Daily Driver
Old 12-07-2005, 08:38 PM
Drew
I'm saying that when you're turning with an open/limited slip diff. the rear tires will have a difference in speed of only a couple MPH give or take and the front will be much more. Which is why you're able to lock the back without as many problems as the front...when turning.
Old 08-29-2006, 07:56 AM
misfitXJ_97 misfitXJ_97 is offline
I got a 97 Jeep Cherokee w/ 4.5" lift 33x12.50s and a detroit locker in the rear that i drive daily. Id post a pic but cant figure it out on here. The rear end does chirp a bit when turnin cause of the locker but thats half the fun of havin one, you should see the looks you get when you put a lifted truck sideways through a turn.
