Old 11-26-2005, 01:13 PM
nikki77 nikki77 is offline
Angry How do I fix a loose steering column?
I have a 1989 Pontiac Firebird that has a loose steering column, how do
I fix this without buying a new column?
Old 12-15-2005, 08:48 AM
formulafirebird126 formulafirebird126 is offline
Re: How do I fix a loose steering column?
i have the same problem. i took out my ignition cylinder to replace it, and i could not find out how to fix it. I think it is only a couple of screws that need tightening back there
Old 12-17-2005, 05:01 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
You have to take the column apart. Pull the steering wheel, turnsignal switch etc., ignition switch and the cover over the column. There are 3 screws near the joint in the column, they do tend to work themselves out after a while. Remove them one at a time, put locktite on them and put them back in. Remember to do this one at a time, if you remove all 3 at the same time you will have to fight with the springs that control the column angle, they are heavy springs and a bitch to reseat. Good luck.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
