Go Back   Automotive Forums Car Chat > GMC > Commercial Trucks
Old 11-26-2005, 12:40 PM
mikeypooh1 mikeypooh1 is offline
normal coolant temp?
Would like to know what is the normal temperature for a truck. I have a 90 chevy silverado with the 5.7 V8. It isalways at about 200-210 Farenheit. think that may a little too high.
Old 11-26-2005, 02:21 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: normal coolant temp?
No, that temp range is perfect.
Your engine is intended to run with a 195 deg. thermostat, meaning that it will not even start to open until the coolant reaches that temp.
If you put a cooler (180 deg). thermostat, the EFI computer might consider the engine is too 'cold' and richen up the mixture a bit to compensate, which would reduce the fuel economy and increase emissions.
Warmer engine run a bit cleaner, more efficiently and last a bit longer.
Old 02-17-2006, 08:31 PM
03CavyMan 03CavyMan is offline
Send a message via AIM to 03CavyMan Send a message via MSN to 03CavyMan
Yep, 200-210 is normal, like MagicRat said, the thermostat opens at 195, and it usually runs a touch warmer than that. I wouldn't get concerned unless it goes over the 210 mark.
2000 Chevrolet Silverado Regular Cab Short Box
4.3L Vortec - 5 speed
Ion Alloy 16x8" chrome wheels
Magnaflow Catback Exhaust
K&N Intake, Throttle Body Spacer
GM Automotive Technician
Previously - 2003 Chevrolet Cavalier
