Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 11-26-2005, 10:50 AM
kat0201 kat0201 is offline
vanity mirror light
My 2002 Sebring's left hand side vanity mirror light do not come on when you flip open the mirror. Dealer says I have to replace the whole sun visor for $400.00. Is there some way to check the light bulbs or connections in the visor. It is of course not covered under my extended warranty and I can't figure how to get to the bulbs with out distroying the fabric on the visor.
thanks
Old 11-26-2005, 10:15 PM
catnypt catnypt is offline
Send a message via AIM to catnypt
Re: vanity mirror light
The maual does say "The vanity lamp is incorporated into visor assembly. If the lamp needs to be replaced the entire visor must be replaced. The bulbs are serviced separately"
So if it is just a bulb out it goes on to instruct... "use a pick or other suitable tool, pry the lens from the lamp". It appears that you lift up lens to access the lamp/bulb.
I can fax you the page with diagram of lens removal and bulb replacement if you like. I should be ablre to look up the bulb you need by then. email [email protected]
John
Old 11-29-2005, 11:17 PM
Re: Re: vanity mirror light
Well with your tip I was able to get to the bulbs, thank you. The bulbs look O.K. but I will still try new ones in there to make sure it is not them. I guess I will not be using the light on that side of the car for a while.
John
