Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 11-26-2005, 09:55 AM
ghostowl ghostowl is offline
Send a message via Yahoo to ghostowl
s13 brake upgrade
ok with all the info i;ve gotten here i'm confussed. will the rotors of the s14 fit to the s13 and how hard is that swap and do the calipiers fit also . if they do than why do some use the rotors from a 300zx and also the calipiers.
Old 11-26-2005, 12:00 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Re: s13 brake upgrade
USDM S14 brakes are exactly the same as the USDM S13 brakes. JDM S14 front brakes are like 300ZX fron brakes. They go to 300ZX fcalipers because the stock ones suck and the 300ZX one rule.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 11-26-2005, 12:04 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
hummm to STOP U BETTER then stock ?!?!
the Z32 brakes are for a 3300+ pound car... 240 is like 2600 lb figur it out..
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 11-26-2005, 12:55 PM
Re: Re: s13 brake upgrade
so if the s14 and s13 are the same brakes don't any companys make brakes for the s13 and s14 that are just as good as the stock 300zx and are probley easy to install on the s13 s14 cars?
Old 11-26-2005, 01:10 PM
Re: Re: Re: s13 brake upgrade
300ZX front brakes are so fucking easy to install on an S13 or S14 that even you could do it. The rears are a little tougher, well they are easy, but it's the handbrake that a bitch, but you don't need the rears, just get the front and the master cylinder and it'll be more then enough, the JDM S14 had 300ZX brakes up front and single piston brakes in back, I think bigger then USDM single piston rear brakes, but still single piston, so don't worry about it.
-Jonathan
Montreal, Canada
Old 11-26-2005, 01:21 PM
cmillerzx cmillerzx is offline
yeah front brakes are a bit easier but should take no longer than 2 hours for a rookie doing it...
Old 11-27-2005, 02:13 AM
I-LOV2XLR8 I-LOV2XLR8 is offline
Send a message via MSN to I-LOV2XLR8
Re: Re: Re: Re: s13 brake upgrade
master cylinder from a 300zx right? direct bolt on just like calipers?
thanks
Old 11-27-2005, 02:48 AM
57r337.Dr1f73r's Avatar
57r337.Dr1f73r 57r337.Dr1f73r is offline
Send a message via AIM to 57r337.Dr1f73r
I heard somewhere that the turbo 300zx had bigger brakes and there was some sort of clearance problem, or am I mistaken? Plus about how much would you be looking to spend if you were to buy the parts needed for the conversion? What is so hard about installing the handbrake?
Seatbelts saved my life
Old 11-27-2005, 02:53 AM
assad_l's Avatar
assad_l assad_l is offline
Send a message via MSN to assad_l
yea i think the twin turbo 300zx does have bigger dunno by howmuch tho.
Assad..
starting 180sx project soon
http://www.youtube.com/watch?v=aGRodKEfeZ4 <<<CHECK IT LOLL
Old 11-27-2005, 02:59 AM
ja_ka24det's Avatar
ja_ka24det ja_ka24det is offline
Send a message via AIM to ja_ka24det Send a message via Yahoo to ja_ka24det
you ever think about doing the 300zx swap up front, and to upgrade the rears for a balanced feel steal the brakes from a infinity Q45, all you really have to do is trim the heat sheild, and re-drill the rotors, otherwise they'll bolt right up
Old 11-27-2005, 03:13 AM
What do you mean by a more balanced feel? if you upgraded the front an back brakes off of a 300zx isn't that what your supposed to feel?
Old 11-27-2005, 03:16 AM
ja_ka24det's Avatar
sorry i read the thread wrong for a second it sounded like only the front was being done and with 300zx brakes
Old 11-27-2005, 02:08 PM
Chuki_breath Chuki_breath is offline
it was, and with the mbc the feel will be alright. Dont worry about the rears.....
i think there are 26mm iron 300z's and 30/32??(cant remember) TT 300z aluminum's. The 26's should bolt right up with no fitment issues....i think lol. Cant remember correctly. But there is lots of info already out there on this, just do a basic search on this and other forums. Should come up with every answer you could possibly want after that.
1993 base model 240sx coupe......to much to list. Just take a look at the link, 10 pages of goods.
http://community.webshots.com/user/nismosilvia240
Old 11-27-2005, 07:00 PM
All 300ZX brakes up front will have fitment problems with stock wheels, but a 5mm spacer takes care of that, but on most wheels that don't suck, there's no fitment problem. The parking brake is hard because the 240 has a disc parking brake and the 300ZX uses a drum. Master cylinder bolts up if you have ABS, if you don't you can make it fit, but I dunno how.
-Jonathan
Montreal, Canada
Old 11-27-2005, 07:35 PM
Ok so a little work for the front an your fine with the 300zx brakes up front. Would it be easier to use the Infinity Q45 brakes in the rear (does it have a disc parking brake)? I'm assuming that you'd have to re-drill the rotors to make em 5 lug? Could you just use the 300zx rotors with the Infinity rear brake setup so you don't hove to drill anything?
