Old 11-26-2005, 07:02 AM
SIRDOUG SIRDOUG is offline
98 Windstar, very little brake pressure and will not hold pressure
As topic says.
When I push the brake, the brake just goes to the floor slowly. There is very little pressure and I have to keep pumping them to get any pressure in the system, but then at that if I keep even pressure on the brake peddel it will still go to the floor.
I have checked the fluid and it stays at the same level. So there is no leak in the system.
Repair history, before this issue.
-Master cylinder
-ABS Computer
-New Brakes less then 500Km ago.
Old 11-26-2005, 07:56 PM
wiswind wiswind is offline
Re: 98 Windstar, very little brake pressure and will not hold pressure
I does sound exactly like air in the system.
Try a very good bleeding....you will need to buy some new brake fluid to do this.
Old 11-26-2005, 09:08 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Originally Posted by SIRDOUG
As topic says.
-Master cylinder
-ABS Computer
Hello
Who did the above work? Why was the above work done? Was the brake system working after the above work being done? When did the brakes start acting as discribe above?
Regards
Dan
Old 11-27-2005, 12:46 PM
Re: Re: 98 Windstar, very little brake pressure and will not hold pressure
Originally Posted by LeSabre97mint
Hello
Regards
Dan
- A licensed mech.
- It needed it.
- The system worked fine after all this. Started doing this pressure issue about month later.
Old 11-27-2005, 09:26 PM
Re: Re: Re: 98 Windstar, very little brake pressure and will not hold pressure
- A licensed mech.
- It needed it.
Doug
I would bring it back to the mechanic that did the work. A brake job shouldn't fail so quick.
Regards
Dan
