Old 11-26-2005, 12:49 AM
highmileage highmileage is offline
94 grand caravan...replaced fuel pump...now backfires!
Hi,
I've got a 94 Grand Caravan LE with 3.8, 175,000 miles.
Last week you guys really helped me out by diagnosing my bad fuel pump. I spent Tueday afternoon dropping the tank and installing a new pump. Van started right up and seemed to run fine. About the second trip out, though, I heard a loud banging sound coming from right in front of the driver side (It really sounded like something banging in the transmission). I popped the hood today and found that its backfiring throught the air filter.
I've got three theories:
Before I replaced the fuel pump, I had put in STP gas treatment and fuel injector cleaner. I refilled the tank with some of the old gas after replacing the pump (filter was changed, too). So, maybe that messed up the fuel system?
#2:
It's very possible that it is coincidence and I have bad wires & plugs. My wife said she noticed the engine bucking and lacking power on rainy days before all this happened. I've got two plugs in the back that have NEVER been changed since I couldn't get to them. They have to be shot by now.
Is it possible that I might have bought a defective fuel pump? I don't see how I could have installed it incorrectly. Would it cause the engine to backfire?
I'd appreciate any advice.
Thanks,
Dave
Old 11-26-2005, 05:18 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 94 grand caravan...replaced fuel pump...now backfires!
I seriously doubt that the fuel pump is causing you problems. I would change the rear plugs along with all the others, wires too. When you change them do a compression check on the engine. This sounds more like a bad valve or stuck lifter than anything else although the plugs may be the entire problem. If you find low compression then you will have to diagnose further.
Old 11-26-2005, 11:09 PM
Re: Re: 94 grand caravan...replaced fuel pump...now backfires!
Yep, you were right! I went ahead and put six new plugs and wires on today and the van runs like a champ. The backfire really had me fooled, though. It sounded just like metal hitting something under the hood from the driver's seat. Not until I revved the engine from the engine compartment did I realize the sound was coming from the air cleaner.
Thanks again for your advice!
Dave
